Wobbly knobs - some help?
Everything Phatty.
tyrannosaurus mark
Post by tyrannosaurus mark » Sun Jan 31, 2010 6:01 am
Hi guys,
I've only ever played one Little Phatty, my own, and I'm concerned that perhaps the knobs (or rather, the pots) on it have been loose from day one. When I hold one of the knobs I can move it around quite a bit (in movements other than turning it), up, down, left, right. Only a little bit, but it means that the knobs are wobbly.
Is this usual? I will go into a music store and try out another LP to see if there's a difference.
If there is a problem, is it hard to swap out the pots on the LP? I'd love to have really firm controls on it, would be more fun to play.
Sir Nose
Post by Sir Nose » Sun Jan 31, 2010 2:32 pm
My stage has loose pots as well, especially the filter section. The value encoder is the knob the worries me the most. I hope at some point in the future if I get around to sending my LP in for the CV upgrade that I'll be able to throw some cash into getting the service department to give the knobs and keys an overhaul.
tyrannosaurus mark
Post by tyrannosaurus mark » Sun Jan 31, 2010 3:33 pm
So you can't open the phatty up and do it yourself, you don't think? The pots look kind of fancy... But so wobbly!
chellebauer2
Post by chellebauer2 » Wed Feb 03, 2010 10:26 pm
How long have you been using it? For sure it is not like that when you get hold of it first.
It might be worn out already.
Also, you won't mind spending a little than replacing the whole just in case you can't get it back right?
Let the experts do it for you.
[url=http://www.Realtime-Vista.com]Cruise Vistas[/url]
tasters
Post by tasters » Thu Feb 04, 2010 5:06 am
also mine, received NEW yesterday, are loose and wobbly.
there's a way to fix this?
thanks!
tyrannosaurus mark
Post by tyrannosaurus mark » Fri Feb 05, 2010 5:20 am
Yeah, after reading stuff online I'm pretty sure this is a known fault, or just part of the synthesiser or something.
I can't send it back to Moog, I don't live on the same continent. I've swapped pots in electronic things before, hopefully this will be no different, I just need to get inside it, but I'm not going to do anything right now, very likely to break it!
tyrannosaurus mark
Post by tyrannosaurus mark » Fri Feb 05, 2010 6:51 am
I've been using it for two years, but it's had this same problem the entire time and I'm pretty sure it hasn't gotten worse. It certainly hasn't become much worse.
Interesting to hear you're having the same problem. Probably just what the stock pots are like I guess.
Prime NL
Re: Wobbly knobs - some help?
Post by Prime NL » Fri Feb 05, 2010 8:40 am
tyrannosaurus mark wrote:When I hold one of the knobs I can move it around quite a bit (in movements other than turning it), up, down, left, right. Only a little bit, but it means that the knobs are wobbly.
Are you talking abut the value knob which is under of the screen..?
If so...this is normal behaviour for a encoder which can also be pressed in for the "select" function.
These encoders are also used on the MP-201...and feel also loose as they serve multiple purposes compared to a normal Pot meter.
These kind of encoders (smaller ones) are also used on my Jomox Xbase 999 drumcomputer...and also feel loose concerning the fact that they can also be pressed for a "select" function.
tyrannosaurus mark
Post by tyrannosaurus mark » Tue Feb 09, 2010 4:59 am
I mean all the knobs, they're all wobbly! Guess I just have to live with it or something
Wibble
Post by Wibble » Wed Feb 10, 2010 5:51 pm
When I first saw a LP in person I too thought the knobs seemed a bit on the wobbly side. Now that I have my own LP though, and this is purely a guess, I suspect that the knobs are mounted on a rubber bush or something that allows a little bit of 'give'. I no longer consider them loose, but accept that that's how they're supposed to be.
kiddell2
Post by kiddell2 » Thu Feb 18, 2010 4:30 pm
I have a new one and mine are the same :lol:
Post by Amos » Thu Feb 18, 2010 9:37 pm
the potentiometers (the turny bits underneath the "knobs" proper) are mounted to the circuit boards; they do not fasten with a nut to the metal panel itself. PCB-mounted pots such as on the Little Phatty typically have more give to them than panel-mount pots. They should be equally durable, though.
