Will a fv500 work as an expression pedal with my mf101
VLtone
Post by VLtone » Sat Jan 30, 2010 10:26 pm
I purchased an fv500H to use as an expression to control cutoff (primarily because im sick of my ep2's breaking) and its definitely not working. I'm not sure if perhaps I was supposed to buy the low impedance version? (fv500L) Has anyone used an fv500 with their moogerfooger and had it worked? Did I buy the wrong one or does this pedal simply not work with a moogerfooger?
latigid on
Post by latigid on » Sun Jan 31, 2010 4:08 am
Once I tried a Boss Exp. pedal, can't quite remember the model. As far as I remember, it didn't work properly, either due to wiring differences or a log taper pot instead of a linear one.
You're using a TRS/stereo cable, right?
Nowhere can I find the actual impedance for the pedal. The expression out probably has a parallel resistor to decrease the resistor value.
But being a volume pedal the response will be log; this is not usually suitable for CV applications.
latigid on
Post by latigid on » Sun Jan 31, 2010 4:13 am
Somebody else has the answer: http://line6.com/community/thread/23643
Some Guy wrote:The Pilot's manual says: Compatible with standard expression pedals, including the Line6 EX-1. Control FX parameters in real time by assigning them to either of these expression pedal inputs. The Line6 expression pedal is a passive 10K ohm mono linear taper pot, using a standard 1/4 inch mono instrument cable.
So the 500L is the one to use, which offeres a single 10K linear pot via a stereo socket connection as well as dual 20K log audio pots via 2 mono input and 2 mono output sockets. A couple of things to watch with the 500L:
(1) You'll need either an adapter cable or to modify the internal connections to the stereo connection for the 10K pot (and off the top of my head, I'm pretty sure a stereo to mono cable WON'T work - I think you'll need ring from the 500L to tip on the M9, with tip on the 500L not connected).
(2) This pedal has a large dead zone under the heel and small dead zone at the toe end with the 10K pot (not sure if it's the same with the 20K audio pots). I'm thinking about putting some wooden chocks under mine so I can feel where there true range is better.
(3) I shorted out the minimum level for the 10K pot so it doesn't matter when this accidentally gets knocked.
So it looks like the pedal will work, my guess is the tip and ring terminals are reversed for Boss applications.
So you don't like EP2s? Care to share?
Portamental
Post by Portamental » Sun Jan 31, 2010 8:33 am
Roland's literature is terse on specifications numbers. According to some data I found, neither will work very well on Foogers. The impedance of the fv500H is 250k, a standard guitar volume pot. That's way too high. The impedance of the fv500l is 25K (according to some sources). If the polarity can be straightened out, this will give you half the range of a standard expression pedal (50k). Log pots? Don't know but not a good sign if there are logs in there.
mayidunk
Post by mayidunk » Sun Jan 31, 2010 8:59 am
Does the pedal have a polarity switch by any chance?
VLtone
Post by VLtone » Sun Jan 31, 2010 10:45 am
"This pedal has a large dead zone under the heel and small dead zone at the toe end with the 10K pot (not sure if it's the same with the 20K audio pots). I'm thinking about putting some wooden chocks under mine so I can feel where there true range is better."
- Yea...that appears to be what is happening. It really only affects the cutoff at around the dead center position between heel and toe. The range is extremely small and thus makes the pedal useless.
The pedal does not have a polarity switch.[/quote]
mayidunk
Post by mayidunk » Sun Jan 31, 2010 11:06 am
What part of the EP2s keep breaking on you?
VLtone
Post by VLtone » Sun Jan 31, 2010 11:49 am
The longest an ep2 lasted was for maybe 6 months, and it started having noise issues whenever I would sweep. That was my 2nd ep2, the first one just stopped working. And I also had an ep1 initially which was god awful.
But anyway, I've moved on and now I'm trying to integrate this fv500 as an expression and it appears that I'm screwed with it now.
latigid on
Post by latigid on » Sun Jan 31, 2010 3:16 pm
VLtone wrote:- Yea...that appears to be what is happening. It really only affects the cutoff at around the dead center position between heel and toe. The range is extremely small and thus makes the pedal useless.
Probably due to the 10k pot inside for the expression section. The EP2 uses 100k, in my opinion 250k would also work.
If you could somehow swap out the pot for a larger one, like the one from your broken EP2, this might be the best way to use the Boss housing.
_DemonDan_
Re: Will a fv500 work as an expression pedal with my mf101
Post by _DemonDan_ » Sun Jan 31, 2010 10:57 pm
VLtone wrote:I purchased an fv500H to use as an expression to control cutoff and it's definitely not working.
Hi VLtone,
While technically, volume pedals can work as controller pedals, I think your situation
would be much easier using dedicated continuous controller pedals.
I've had success with these:
http://www.sweetwater.com/store/detail/EV5/
http://www.sweetwater.com/store/detail/EXP2Pedal/
http://www.m-audio.com/products/en_us/EXP.html
One interesting difference between the Moog EP2
and the other pedals is that the EP2 has a knob that lets you set the *maximum*
amount while the above pedals let you set the *minimum* amount.
Both of those knob functions are useful when taming 'foogers so it's good to have both kinds.
[FEATURE REQUEST]
A CC pedal that had both a minimum *and* a maximum knob would be staggeringly useful!
oilcanracer
Post by oilcanracer » Thu Feb 04, 2010 2:56 pm
maybe if everybody posted with the pedal that did work for them we can get a list of pedals making it easier for people searching for this.
Alien8
Post by Alien8 » Fri Feb 05, 2010 1:43 pm
I'm using the FV500H, and it works great... I'm 250lbs and stand on it regularly. No issues with travel, or dead zones... Works on all foogers.
t.shamone
Post by t.shamone » Sun Feb 21, 2010 11:38 am
oilcanracer wrote:maybe if everybody posted with the pedal that did work for them we can get a list of pedals making it easier for people searching for this.
I use the Ernie Ball volume pedal and it works great. It even has a taper switch which I never had to touch. Plus it's built like a tank. I didn't buy it for the Fooger, but now it's like a triple duty pedal.
Tyler Kirschner
Post by Tyler Kirschner » Thu Jul 14, 2011 4:09 pm
Hmmm.... I recently got a MF-101 and tried controlling the cutoff with a fv500l and for one reason or another the resonance bugged out when i did this. i don't think it was turned up all the way, but it didn't work anyways. I was using a TRS cable with it. Is there a chance that I shorted something out by doing this?
