Now that's something I'd save up some pennies for. It'd look beautiful. The above mockups are quite delicious as well.Voltor07 wrote:Beautiful mock up...I'd like to make one minor change though.Make the back a square, and make it deep enough to hold either a Moog LP or Voyager. Then I would DEFINITELY buy it for 4-6 grand!
what should moog release next?
Little Phatty Stage II #3602, MoogerFooger CP-251 #1785
MF-103 12 Stage Phaser #6093, MF-104m Analog Delay #0301
My band: www.facebook.com/InstantMorning
8 Voice Polyphatty: On the right is la little space for controlling something more.
* I whish a second Filter
* maybe noise
* and the possibility for easy changing the filter (6/12/18/24-db LP/HP) each patch and storing.
*Stereo out.
Option: only a box with 8 voices, playable from LP or an expander.
at last a Stereo-MF-101 or a possibility to control 2 of them identically from one.
That's all.
* maybe noise
*Stereo out.
That's all.
audio out left to 1st mf101, audio out right to 2nd mf101, turn amount to 0 on 2nd mf101, patch envelope out from 1st mf101 to cutoff of 2nd mf101 OR envelope out to cp251 to invert,lag,or what have you then to 2nd mf101 cutoff. I believe that should give you a stereo filtersmut wrote: at last a Stereo-MF-101 or a possibility to control 2 of them identically from one.
The LP is a nice monophonic but the architecture is not flexible enough. It would be a rudimentary polyphonic.
The Voyager is better equipped and can be chained as part of a polyphonic system. But if you bought six Voyager RMEs, five of them have redundant pots and switches which cost $$$.
A good solution is Voyager brains with no pots. This reduces the $$$ for a polyphonic system and all you need is a Voyager or editing software. Add as many brains to create an N-voice polyphonic. Much like the Oberheim SEM polyphonic.
You gotta remember this is coming from someone who cut his teeth on a Memorymoog - I got a lot of mileage out of that thing. The LP does not have the modulation capabilities of the Memorymoog and that can open a lot of doors to tone varieties. The Voyager modulation does exceed that of the Memorymoog though.
Moog would do good to study the (ARP) Rhodes Chroma (not Polaris) as an example on how to do a proper hardware design for a polyphonic:
I've been studying the design of classic VCO-based polyphonics, and the Chroma struck me as a superior design. When those ARP guys got down to work, they could really put out a maverick design.
- * DACs on the voice cards. This reduces connector density and eliminates oxidation problems that wreak havoc with CVs. Many of the classic polyphonics' put the DACs separate from the voice cards and carry the CV through connectors. Their infamy with reliability is due to oxidation of connector contacts which degrades CV (and hence tuning).
* Configurable voice cards. The Chroma voice architecture can be configured in 15 different systems, each giving a radically different sound.
* The last two design features give you multitimbrality.
* S&Hs with fast/slow update paths. The Chroma used software EGs and LFOs which gave it a flexibility not possible with hardware EGs (and they're quite snappy enough). The fast update paths were used for EGs/LFOs while the slow update paths were used for pitch/filter/VCA CVs that did not require high speed updating. This took a big load off the microprocessor.
* A dual DAC system in that the main DAC's reference voltage is the output of a reference DAC. What this did was permit range AND scale to be under control of the microprocessor. The Chroma had the fastest autotune in the west thanks to this system - one second for all eight voices. For each voice, it generated a low and high CV for expected frequencies and measured the actual frequencies at those CVs. Now you can solve for range and scale using the classic linear y = mx + B formula. Because it was so fast, the Chroma could autotune behind the scenes on voices that were inactive.
6 voyagers brains and we're easily back up into the stratosphere price-wise. I don't think 3 oscs +voyagers other features on a poly would be prudent for them even a little bit, even if it was a "special project" synth like the Taurus III. It'd make the thing just too expensive.
2 Oscs with a more flexible modulation system, and maybe a HPF like the Voyager has would be more than enough to create a great poly at a price point in reach for more than 12 people. Guess we'll see what they cook up.
www.ctrlshft.com
- superd2112
Thats the whole idea - a basic poly with real Moog sound, at a price point we can all afford. Huge sounding pads, but no frills. No sense it trying to out-do the Andromeda - theres just no way Moog could bring it in anywhere near the $3k price point. Moog could build the ultimate 16-voice $6k+ poly monster, but they would never be able to sell enough of them to recoup the development & tool-up costs.MC wrote:The LP is a nice monophonic but the architecture is not flexible enough. It would be a rudimentary polyphonic.
No sense trying to out-do the Andromeda.
No sense trying to re-invent the Polymoog either, which is what a polyphonic LP will sound like.
It doesn't have to be the ultimate poly monster, but I've progressed past the "basic poly" years ago.
So how many voices then do you think are acceptable?
I say 10 is a nice number. You now if you go < 8 then people will cry "But the Prophet...", but if you go more than 8 then the $ factor comes into play.
In a self contained unit (hopefully one that will hold the Voyager on its chassis) how many voices?
I don't think I would want to buy a Moog synth just to turn around and get a cheap MIDI controller to go with it.
Most of us already have MIDI controllers.
I use a Kurzweil MIDIBoard. Weighted action, velocity and release sensitive, control of all my MIDI devices, polyphonic aftertouch - one serious controller.
If the moog polysynth had a rudimentary keyboard integrated into it, it is redundant as I am going to control it from the superior MIDIBoard.
SE does alright without integrated keyboards on their synths.
- Christopher Winkels
To quote the LOLcats:
Do want!
I like the idea of adding some of the secondary (menu) controls like noise, filter poles, secondary modulation routings, etc. and adding them to a control space on the right hand side.
Other than that, it's perfect.
Give me six voices with room for additional voice cards that socket in place in under two minutes (give two voices per card, up to a maximum of 12 voices total) so that the cost of entry is around $2,000 to $2,500 for the basic model with additional cards for a few hundred apiece.
Best Idea Yet!....as long as i can buy it tooBryan T wrote:I think Moog should release the Bryan T starter pack. It would combine an Old School Voyager, a Moog guitar, and an MP-201. Priced at $1499.
Pretty please?
Well some might prefer the BrianB starter pack that includes the Paul Vo Collectors Edition Guitar, a Voyager Select, and the Mp201 with the brand new operating system. Priced competetively at 1498.95.
I like the Voltor starter pack...two of each Mooger Fooger, a Little Phatty Stage II, a Voyager OS whitewash, and a polysynth for $3998.99.
