Looking for used Voyager-any upgrade limitations/problems?
I have been shopping for a used Voyager and wondered if certain versions were dead ends as to upgrade path or OS compatibility?
Are there model or serial number cutoffs that should be avoided in order to ensure some level of future proofing?
TIA for your input.
Regards,
MM
TIA for your input.
Regards,
MM
My understanding is that any Voyager can be made identical at this point. Older Voyagers only have a single hardware bank for presets but can be upgraded to the seven bank setup for a few hundred bucks.
Other than that, I'm pretty sure all other components are identical or close enough to identical that it wouldn't affect upgrades. I'm a musician and not a techie though, so there are more qualified people on here to confirm or deny this.
[b]ΔΔΔ MARS PYRAMID RECORDS ΔΔΔ[/b] - www.marspyramid.com
www.myspace.com/marspyramid
[b]Aether Everywhere Records[/b] - www.aethereverywhere.com
[b]VIKOMT[/b] [i](harsh drones)[/i] - www.myspace.com/vikomt
Welcome fellow Sig owner (I've got maple Sig #167!). RE: updates. I've got the latest OS (3.4) on mine, and it workes just fine. There were a couple other fixes done to the series later besides aftertouch upgrade. Namely the filter glide fix, the slight click if you move the volume knob around 12 o'clock, and (I think) a VCA upgrade (it was some kind of upgrade to help w/ unwanted noise IIRC). There's also a retro-fit you can do to get all 7 banks of presets. Personally, all I've done to mine is the OS updates. The noise/click/filter glide/aftertouch would all be nice, but nothing I feel I need to do immediately. Well, if you can call almost 7 years "immediately"...
-andrew bunny
-andrew bunny
Thanks everyone!
I will probably get it fully updated & tweaked after the start of the new year.
In the meantime, waiting for the synth to make its way cross country will try my patience.
Regards,
MM
Regards,
MM
Voyager RME, 1974 Model D, Model D Reissue, MultiMoog
CP251-MP201-VX351-VX352-MF101-MF102-MF103-MF107
Moog Parametric EQ, 500 Series Delay (2), 500 Series Ladder Filter (2)
