Getting a broken LP fixed in UK - any experiences?
I am having a lot of trouble with my LP Stage as it has frozen while I was updating to 2.2 (As I have explained in 'My LP is dead' thread), I have tried the debugger route which has also been unsuccessful so am now thinking I may have to send it back to moog from the UK. Has anyone done this? If so any advice on best method / cost effective way of sending it and how long it takes and how expensive it might be to fix?
Also has anyone used anywhere in the UK to help with this kind of issue? I see Cimple in London have been mentioned, I would love to know if anyone with a similar issue has managed to get it sorted out like this? Any advice greatly appreciated - thanks.
My LP froze, not immediately upon the update, but a few days afterwards. Nothing I could do to get it to work. It was still under warranty so I took it back to the retailer and they sent it to the Moog UK distributors who fixed it. Took about 3 weeks. I wasn't charged because it was under warranty. Outside warranty I guess they would have charged.
Another engineer here said that he's often gotten that same error when trying to connect to the USB debug adapter, if he's using a USB hub or sometimes the USB ports on the front of computers (these front ports are typically not directly attached to the motherboard, like the ones on the back typically are). So you may have a dodgy USB connection or a faulty debug adapter. If you'd rather send it to a tech at this point, I'd compare prices between Cimple and HHB... and might recommend HHB (just because we're in closer touch with them these days - no slight against Cimple Solutions intended).
I just had a good talk with our head engineer about this today. We're actively working to improve the firmware update process and make it more robust. I am truly sorry for the problems thus far, and am committed to making it a safe and reliable procedure in the future.Lowdene wrote:Amos, reading across the forum there seem to be a very high number of problems related to firmware updates. Is there any way of making this more robust?
Re: Getting a broken LP fixed in UK - any experiences?
Mine has just done the same not at all happy
