MY RING MODS GONE MUTE!
This is sad my carrier signal is no longer connected to the audio path! i just sent moog an email so hopefully this is easy fix. anyone else ever have this problem?
never happened to me, but i would ***assume*** that moog uses a shorting jack on the 'carrier in' input. so, the internal carrier is connected to the ring mod via a signal path that travels through the 'carrier in' jack. when you plug an external carrier in, the internal one is diconnected mechanically.
long story short, it's probably something in your 'carrier in' jack that isn't making contact and needs to be bent (slightly) back in place.
- latigid on
Yeah the carrier out to carrier in was the first thing I tried. Figured hey its a little ghetto but it will do, and when that didn't work I was like oh man this can't be good...
- latigid on
Yeah carrier out still works, but the mix knob basically acts as a volume knob
