ARP & CP-251 ?
square
ARP & CP-251 ?
Post by square » Thu Nov 18, 2004 12:23 pm
I have an Arp Odyssey and was wondering if it was possible to use the CP to send CV to the Arp? And if so does anyone know where I can find a cable (im sure I could make one but my craftiness isn't the greatest) to convert from 1/8" to 1/4"?
and any other pointers on doing this would help
thanks!!!
S
peter ripa
Post by peter ripa » Fri Nov 19, 2004 4:10 am
absolutely, just get a mono 1/8-1/4-converter in any radio store
www.peterripa.com
http://www.peterripa.com/cgi-bin/index.cgi?action=musik
square
Post by square » Fri Nov 19, 2004 11:55 am
i tried sending a signal out from the cp-251's LFO and S&H but nothing..
so either A. im doing something wrong or B. the CV on my odyssey is no good..
monads
Post by monads » Mon Nov 22, 2004 6:40 pm
I take it you plugged it into the CV IN on the Odyssey...correct? Try the LFO from the CP-251 plugged into the Odyssey this way...play a note, anything?
I don't think you can use the Gate/Trigger In on the odyssey as they require an +8 V minimum and the CP-251 isn't cable of this.
Progger
Post by Progger » Mon Nov 29, 2004 6:16 pm
I do not have an Odyssey, but can say that this does work with my ARP Axxe III. The 1/8 inch jacks are weak, I have to jiggle the cord in place until it "catches".....perhaps you have the same problem? The sample and hold on my Axxe does not function, so the CP really came to the rescue in this case.
