MichaelPeterTrowbridge wrote:@Bryan
Thanks;-) I have already managed to "sync" the Murf to the MIDI Clock of my MicroKorg via a Doepfer MIDI/CV interface.
That worked because of how the MuRF receives its time information. The analog delay works differently.
I should be able to do the same with the analogue delay shouldn't I?
No. The 104 gets its delay time from a fixed voltage level, not from a clock, gate, or LFO. The MP201 would need to convert the clock tempo to a fixed voltage level. It doesn't do that. There's a good thread on the issues involved elsewhere in this forum.
The MP-201 can receive MIDI Clock right?
Definitely, though it works best over a MIDI cable. USB was a bit buggy the last time I tried it.
Would "programming" the MP-201 to send different tempos on the separate CV-Outputs be a complicated thing to do?
Not tough at all. As it is, I think you could sync four MuRFs to different divisions of the same MIDI clock.
Bryan
