LFO in Live problem.
Everything Phatty.
the electric arc
Post by the electric arc » Sat Dec 13, 2008 5:11 pm
I have a Phatty Stage II that I plug into the MacBook running Live 7 via USB. Midi notes all work fine, but once the Phatty is hooked up to the computer, the LFO goes completely screwy. I can't get it to sync with the live clock, though I have the settings correct in the OS. Not only that but the action of the mod wheel and amount adjustment just seems to do a pitch shift of +2 or 3 by adding harmonics (almost like osc2). All the routing from sources produces various versions of the shift, but no distinct LFO action.
If you can think of anything I can check in either software system, let me know.
Thanks for your help!
arc-itect
the electric arc-itect
LP Stage II, MF-101, 1974 Rickenbacker 4001, Apple MacBook, Ableton Live 7
www.myspace.com/theelectricarc
Post by EricK » Sun Dec 14, 2008 2:18 am
I have not had ANY success with Midi as of yet (except from instrument to instrument) but Im assuming that you know that you can't get a full sync of an analogue LFO, but just the start of it.
Something I read in the Voyager manual the other day about making the LFO half of the speed of the clock setting so that it would never drift off tempo because it was syncd and retriggered by the midi clock.
At least I hope im telling you correctly.
Maskin
Post by Maskin » Sun Dec 14, 2008 8:43 am
Eric, the LFO in the Little Phatty is digital so in theory that shouldn't be a problem.
Ask Amos, he uses Live too so he might be able to help you out.
[size=75]"I like to play with electronic noise makers. I hope someone wants to listen, and if not, I'll still be up at 3 am making sequences in the dark, drinking coffee, and burning expensive incense." [i]Rod Modell[/i][/size]
the electric arc
Post by the electric arc » Sun Dec 14, 2008 12:26 pm
I think I've found something...
http://www.moogmusic.com/forum/viewtopic.php?t=5978
I'll try this to see if it is the problem.
I'll get back to this forum soon and let you all know, in the meantime, any thoughts from you Amos, if you're out there...?
arc-itect
Post by Amos » Mon Dec 15, 2008 12:15 pm
Hi, more details would be helpful.
If you are sending/receiving/echoing MIDI from the LP to your sequencer back to the LP, then be sure that LOCAL CONTROL is turned OFF - you could be getting some odd behavior if there's MIDI feedback happening.
Other than this suggestion, I need some more specifics about what's going on. What sequencer, how is MIDI connected, what specifically is going wrong as best you can explain it...
Good luck,
Maskin
Re: LFO in Live problem.
Post by Maskin » Mon Dec 15, 2008 7:53 pm
:mrgreen:
Post by EricK » Mon Dec 15, 2008 8:08 pm
Sorry I thought it was an All analogue LFO.
Could that be why the LP has an arpeggiator and the Voyager does not?
Is that even related whatsoever?
Maskin
Post by Maskin » Mon Dec 15, 2008 8:34 pm
EricK wrote:Sorry I thought it was an All analogue LFO.
Good question!
