Does TE sound bank work with SE2
Everything Phatty.
narrowcaster
Post by narrowcaster » Thu May 29, 2008 8:57 am
Does anyone know if I can safely/effectively load the sound bank for the TE into the SE2? I'd be curious to check out those presets, but I don't want to gum anything up...
numbersix
Post by numbersix » Thu May 29, 2008 10:00 am
I have loaded and played Stage II presets on my LP Tribute without any problem.
I would imagine that it would be ok going the other way.
I asked Amos a similar question via this forum a while ago.
His reply is below.
Hope that helps.
Post subject: LP Stage factory presets on Tribute?
I think this may have been questioned in the past.
Can the LP Stage Factory Presets be downloaded from the Moog website and used on a LP Tribute?
If I remember correctly,the answer is YES,but some patches are specifically designed for the different configuration of the Stage.As a consequence,may not sound so good on the Tribute.
Does my memory serve me well?
Amos Replied:
Correct!
The only difference in how the patches will sound is that if there is a second modulation destination programmed into the patch, you won't hear the result on a Tribute. So, all the patches should sound the same with the mod wheel down. :)
Moog Little Phatty Tribute.
narrowcaster
Post by narrowcaster » Thu May 29, 2008 12:32 pm
Perfect, thanks...
Post by Amos » Thu May 29, 2008 12:37 pm
TE sounds should work perfectly on any Little Phatty. :cool:
