Analog Delay power puzzle
linearnorth
Post by linearnorth » Thu Apr 24, 2008 11:37 pm
I'm also having this problem with my SD. Thanks for the info.
[url=http://myspace.com/ascentcove]Linear North[/url]
[url=http://phobos.apple.com/WebObjects/MZStore.woa/wa/viewAlbum?i=274164192&id=274163874&s=143441]Check out my new EP "Make Peace With Culture" on iTunes. [/url]
Bryan T
Post by Bryan T » Fri Apr 25, 2008 4:04 pm
linearnorth wrote:I'm also having this problem with my SD. Thanks for the info.
I hope you get your SD sorted out. Mine is being worked on at Moog right now. When I sent it in it wouldn't do a single repeat, but now that it is there it works fine. I hate intermittent problems!
Bryan
buzzlegs
Post by buzzlegs » Thu May 01, 2008 10:46 am
I too, have just started having problems like this on my SD delay :-(
prize
Post by prize » Fri May 16, 2008 2:03 am
is this going to be a problem for all MF-104SDs ?
can we get an official response on this as and I would prefer a preemptive fix if its a problem across the board.
linearnorth
Post by linearnorth » Mon May 19, 2008 5:21 pm
I switched the SD power supply with the one from the phaser and it works fine so far.
Maskin
Post by Maskin » Mon May 19, 2008 6:57 pm
linearnorth wrote:I switched the SD power supply with the one from the phaser and it works fine so far.
I did the exact same thing on my 104Z on stage some weeks ago when I discovered it sounded dull, it worked perfect after switching. :)
Funny part is that I have the original power supply attached again and it still works perfect.
[size=75]"I like to play with electronic noise makers. I hope someone wants to listen, and if not, I'll still be up at 3 am making sequences in the dark, drinking coffee, and burning expensive incense." [i]Rod Modell[/i][/size]
matt the fiddler
Post by matt the fiddler » Mon May 19, 2008 9:56 pm
I figured out what is wrong!
you need to send my your 104sd, and I will send you a 104z that works :)
Electronic Violinist here
Bryan T
Post by Bryan T » Wed May 21, 2008 9:50 am
Another update: I received my delay back from Moog yesterday (I should have had it last week, but UPS is completely incompetent). Ryan at Moog replaced the 'guts' and everything is working as it should. Great service from Moog.
Bryan
