12 stage Phaser is AMAZING
Paulkaiju
Post by Paulkaiju » Tue Apr 15, 2008 4:39 pm
I've had it for about a month and I've mostly been using it with my Doepfer gear LFO what have you and I finally ( :shock: ) hooked it up to my LP out and wow is that thing tight! it really showed it's colors there!
I also use a theramin with my Freqbox as well as with the LP.
These things just keep on giving!
Praise! Amazing!
I'm thinking about a CP or Delay next.
Post by EricK » Thu Apr 17, 2008 1:02 pm
Have you had a lot of success with the Theremin and the Freq Box?
THe theremin and the Delay sound so fantastic together it is really to be lived to understand hehe.
I noticed with my theremin and freq, once you pass a certian point in theextreme upper registers (like an inch from the antenna), the Freq will create a sum and difference and it will ring modulate. You will specifically hear the sun and differences reverse themselves. I totally wasn't expecting that.
I also like with the Freq, to have an expression pedal on the mix knob and when im playing the Theremin, turn up the mix and youll hear the cp251 driven S&H. Its a cool effect.
Do you have the etherwave theremin or are you using the Doepfer one?
Perhaps a voltage controlled theremin?
