I am going to control them with my MicroMoog.
Now Im trying to picture in my mind how to use the Driver with the 921B and if I don't intend on using the Driver, where Im supposed to put the input control signal for the OSC.
Heres what Im thinking....
1. MicroMoog S-Trig out to the S-Trig in on the Envelope Generator
2. Env Gen out to Control input on VCA
3. OSC out from MicroMoog to SYNC IN on 921B *
4. __Wave output to input on env gen.
here is a picture of the 921B Module
*Will I have to use the Osc Driver any time that I use the 921B? Like will I run my OSC out to the FREQ in on the Driver
I am pretty sure that since the Micro will be used as the controller then instead of using the ENV and the VCA, I can simply route the OSC back into the Micro for filter-env-vca processing all internally.
WHat im not quite sure about though is what exactly AC and DC modulation is.
Any help will be greatly appreciated. Anyone that can offer any insight into the function of the Driver will be praised.
Respectfully,
