Will Voyager RME and VX351 work as a MIDI to CV convertor
davemoog
Post by davemoog » Thu Dec 20, 2007 6:27 pm
Will Voyager RME and VX351 work as a MIDI to CV convertor when a MIDI keyboard is plugged in to it?
I already own a Doepfer MIDI to CV for my older analog synths, a Voyager RME and the VX352. However an additional MIDI to VC/Gate convertor would be useful if this would work with the VX351.
Thanks Dave
GregAE
Re: Will Voyager RME and VX351 work as a MIDI to CV converto
Post by GregAE » Fri Dec 21, 2007 8:17 am
davemoog wrote:Will Voyager RME and VX351 work as a MIDI to CV convertor when a MIDI keyboard is plugged in to it?
Yes, an RME and VX-351 can be used for this - in fact, it may be the most expensive MIDI/CV converter on the planet. :wink:
CTRLSHFT
Post by CTRLSHFT » Sat Dec 22, 2007 2:46 pm
yeah I use it w/ my RME and MF-107 for a 4 osc synth. You can also mix pitch bend settings w/ a cp-251 so that when you pitch bend your RME from your midi controller, the mf-107 osc will pitch bend the same amount!
www.ctrlshft.com
analoghaze
Post by analoghaze » Sat Dec 22, 2007 6:54 pm
I use my Voyager as a MIDI to CV converter alot. I use the Nord G2 as a crazy sequencer, because it has Multiplexers with X-fade. Using that CV to control other things like the moogers is great!
GregAE
Post by GregAE » Sun Dec 23, 2007 10:13 am
CTRLSHFT wrote:yeah I use it w/ my RME and MF-107 for a 4 osc synth.
If you have the MF-102 Ring Modulator, you can do the same thing. Although the oscillator in the '107 is more versatile, the carrier oscillator in the '102 will also provide a 4th osc for an RME or Voyager keyboard.
analoghaze
Post by analoghaze » Sun Dec 23, 2007 7:42 pm
I do this alot with the 102. Actually, it is one of my favorite features of the RM.
It sounds awasome.
CTRLSHFT
Post by CTRLSHFT » Wed Jan 02, 2008 8:24 pm
aye, i have one! :)
the 102 doesn't seem to track as well though, unless i get a cp-251 involved; even then usually it falls apart after an octave max. not bad for bass, though.
www.ctrlshft.com
chinard
Post by chinard » Thu Jan 03, 2008 11:35 pm
CTRLSHFT wrote: the 102 doesn't seem to track as well though, unless i get a cp-251 involved; even then usually it falls apart after an octave max. not bad for bass, though.
the 102 tracks just fine, just remember its linear (hz/v) not exponential (oct/v) so you have to compensate with an attenuator.
The 'lord of the ring mod' document on moogspace has all the gory details. in a nutshell: pitch through attenuator set at about 7 then experement going up and down octaves until it pitch tracks properly.
i use my 102 as a 4th oscillator all the time and its pretty nice even though it only outputs one waveform (triangle)
would be nice to get a freq box for the extra waveforms, sync, fm, etc..... maybe santas elves will make me one next xmas :wink:
GregAE
Post by GregAE » Fri Jan 04, 2008 8:05 am
aye, i have one! :)
Check out the "Lord of the Ring (Modulator)" article for more on setting up and using the RM as a fourth oscillator or a tracking modulator. Find it here:
https://www.moogmusic.com/members/?sect ... file_id=41
You don't need a CP-251 for this.
Post by EricK » Fri Jan 04, 2008 1:37 pm
Man that is a fabulous article!
