Do you guys have any recommendations which units may be applicable & where I can start educating myself so that I'd know what is possible?
TIA
i agree with this recommendation, as i've been using one with my LP for a while now with great success.OysterRock wrote:I've heard good about the Future Retro Mobius:
http://www.future-retro.com/MOBIUS.html
Hey CTRLSHFT, I think I've finally decided on the Mobius with a CP-251! Where do I connect the V/Oct & Gate outputs & what are your settings for the Gate Type on the sequencer & the settings on the CP-251? I have some questions in to AnalogueHaven as I'm still unclear on a few things.CTRLSHFT wrote:i agree with this recommendation, as i've been using one with my LP for a while now with great success.OysterRock wrote:I've heard good about the Future Retro Mobius:
some pointers if you get one though:
1) The gate output is 12v, this is too much voltage, and the LP will not respond to it (or not respond to it properly if you try and send -12v). You will need something that can attenuate the signal to +5. Hello CP-251!
2) Due to a DC biasing issue, when you hook up the cv pitch voltage jack to the LP, the LP will transpose everything up approximately one semitone. You can either transpose the key on the LP kb down a half-step, or use the offset on a cv mixer (cp-251 to rescue again here) to get the pitches between when you press a key on the LP and when the sequencer plays the same note (toggle between the two with the cv mixer's output jack).
3) you'll probably need to calibrate the mobius's cv output voltage. i had to do this to get things to scale properly.
That is really something I wish for in a future OS update. A built in sequencer/arpeggiator would help me a lot.rachel wrote:I would love for Moog to produce a sequencer/arpeggiator for the LP, in the same style.
It could be MIDI controlled and output both CV/Gate and MIDI. Of course you should be able to
use it with any instrument, but let's hope it had the same LP styling, along with a track memory
and so on!
rachel
I'm going to pick up the Mobius to sequence my SH 101 and am also curious about how it will get along with the Phatty.CTRLSHFT wrote:
