One POWER adaptator for multi mooger
alx002
Post by alx002 » Mon Jul 09, 2007 6:37 am
Is it possible to use only one Power Adaptator with 3 or 4 moogerfooger?
Which adaptator do I have to use ?
thanks for all
Alex
Robzilla
Post by Robzilla » Mon Jul 09, 2007 9:37 am
you need to know how much mA your pedals will ask in total. Any adapter that can deliver enough power will do. Be sure you get a adapter that powers your Moogs in the right way, MoogerFoogers need a powersupply that has reversed polarity (contrary to a Boss pedal, for example..)
The Visual Sound One Spot delivers 1700mA (1.7A). They have little adapters that reverse the polarity of the adapter. I use one for my Moogs..
jamirokid
Post by jamirokid » Mon Jul 09, 2007 3:34 pm
I have the onespot too and it works good in a pinch. For recording I suggest getting seperate supplies and a monster or similar p.s. Using one adapter is possible but its awfully noisy.
Josh
DeFrag
Post by DeFrag » Mon Jul 09, 2007 9:07 pm
I thought someone stated on a similar thread that each Foog wanted its very own power adapter or noise crept in.
Little Phatty TE #1023 • Schrittmacher • Walking Stick ribbon • Korg microXL/Electribe MX/KaossPro • Sonnus G2M
MF-101 Filter • MF-102 Ring • MF-103 Phaser • MF-104Z Delay • MF-105 MuRF • MF-107 FreqBox • MF-108M Cluster • Etherwave
_/_/_/_/_/_/_/_/
redeyeflight
Post by redeyeflight » Tue Jul 10, 2007 11:27 am
this is true. the one spot power supply moogerfooger adaptor says that running mutipule moogerfoogers off it will create excessive noise. Your best bet is the voodoo labs power supply. I've been running five moogerfoogers off of it for years with no problem at all! Just remember to order those reverse polarity cables so you dont fry the foogers power supply!
shakti
Post by shakti » Tue Jul 10, 2007 9:09 pm
I would like to power all 8 of my MFs from one small power source such as the Voodoo labs power pedals II.
Would I be able to use all 8 of the VLPPII outputs seeing as how one of the MF pedals is a murf which i think might require two of the VLPPII channels to be combined to increase power. Does that sound right?
DeFrag
Post by DeFrag » Wed Jul 11, 2007 6:06 am
What makes the Voodoo Labs unit different in that it won't introduce noise with multiple Foogers?
_/_/_/_/_/_/_/_/
latigid on
Post by latigid on » Wed Jul 11, 2007 1:44 pm
I'm guessing, but:
1) With a high current rating, you eliminate 50/60 cycle hum. With a low current supply, you tend to start drawing current from the mains, which gives you the hum.
2) Torrodial transformers are much less prone to noise interferance than standard wound ones.
3) Or, good switchmode PSUs are quiet ( ? )
4) Placing a diode on each input and output of a multiple supply or daisy chain can block crosstalk between the power sections of adjacently connected units.
dzy88p
Post by dzy88p » Sat Jul 14, 2007 6:22 am
I've been using Voodoo Labs Pedal Power (not II) for several years as well. As far as I can tell, no noise, no problems whatsoever. As previously mentioned, the connectors are a special order item. Saves a lot of room in my studio power center.
