midi playback problem
jaded bob
Post by jaded bob » Fri May 07, 2004 2:00 pm
The playback of midi notes doesn't happen correctly it misses most of the notes, on any patch, midi channel.
(winxp / cubase sl2 / motu 828 / midex 3 / tryed both midi interface.)
I've upgraded the software from 1.5, my access virus when plugged into that cable plays fine, and the moog lights with all the midi data but not all the notes sound (very few). It records the notes and data ok, have i missed something.
thanks joe
MC
Post by MC » Fri May 07, 2004 7:14 pm
Press the MASTER button and go to "MIDI Key Order".
Press ENTER and use the "-" button until the display reads "MIDI In Key Order is not active"
MIDI Key Order is a new feature in v2.x when you upgrade from v1.5. By default this is enabled, and you have to manually disable it.
jaded bob
Post by jaded bob » Sun May 09, 2004 5:54 am
that sorted it, i' d seen that in the manual and thought i'd fixed it. Thank you. joe :D
