Midi Rx - Pitch Bender?
I was trying to record midi data from my LP SE to Cubase or something similar.
Recording is OK, the LP sends all data correctly, but when I playback the things I've recorded from any sequencer, the range of the pitch bender don't correspond to the settings I've used...
Ex:
if I record using pitch bender UP:+12 DN:-12, when in playback via MIDI it sound like it's +2 and –2
Is there a solution for this? Is there something I missed?
Ex:
When you record pitch bend, all you're doing is recording a number value 0-127. If you play it back it should change the pitch according to whatever the pitch wheel was saved to. The pitch change amount is determined by what the settings are on the patch you're using on the LP, not Cubase. In other words, if your patch goes from -2 to +2, in Cubase 0 will be -2, 64 will be 0, and 127 will be +2. If your patch is -12 to +12, in Cubase 0 will be -12, 64 will be 0, and 127 will be +12. Were you playing the part back on a patch that had saved your -12 to +12 pitch bends?
