Voyager Keyboard OS 3.3
SteveD
Post by SteveD » Thu Feb 22, 2007 6:32 pm
Hello Voyager people!
We've made available a new Voyager OS, it's version 3.3. This week we have the Keyboard version available - next week we should have the Rack Mount version available too.
Go to a Voyager product page and click the software link, it should be the last file on the page. The three firmware banks are in a .zip folder with user notes.
Here's a quick overview of the new features:
1) Local Control On/Off - Local Off now turns off the front panel controls as well as the keyboard, and the state is remembered after power down.
2) MIDI Key Order - you can now select the number of Voyagers in your set up from one to 16 for polyphonic playing.
3) Save Preset - now you can easily save to any of the 7 preset banks (if you have the 3.x digital board)
4) Pitch Bend Amount - separate Up/Down Amounts are stored in a preset
We hope you enjoy the new features.
Thanks to Rudi Linhard for yet another OS upgrade!
Best Regards
Steve Dunnington
Moog Music
sir_dss
Post by sir_dss » Thu Feb 22, 2007 10:45 pm
That is so awesome...
http://www.myspace.com/sirdsssound
http://en.wikipedia.org/wiki/David_Scott_Stone
earsmack
Post by earsmack » Fri Feb 23, 2007 10:53 am
Installed fine here upgrading from the previous latest version. Will report any problems.
Minimoog Voyager Performer Edition + LP Stage II + Sub37 + Model D reissue + CP-251 + VX-351
gd
Post by gd » Fri Feb 23, 2007 11:41 am
do I have to install 3.2 first as I have just never bothered but this upgrade is one that I definately will do.
Mini D, P'08 ..
RL
Post by RL » Fri Feb 23, 2007 12:09 pm
No, but it is very important to save your presets before you make the upgrade. After the upgrade you should make a factory reset before you re-load your presets (MASTER/COPYRIGHT INFO/ENTER/+1/ENTER/CURSOR-->YES/ENTER).
Have fun,
Rudi
earsmack
Post by earsmack » Fri Feb 23, 2007 2:12 pm
Have fun,
Rudi
I did *not* back up my sounds before the update so I decided to do it now. I thought I was backing all sounds up but it seems that the receive presets/send presents only works for the current bank and not all banks - is this correct? Also, resetting to the factory presets sets the current bank to the original 128 patches only not the 128 that were in that bank otherwise - is that right? That is...if I reset bank A and B and C they will contain the patches starting with "I'm Baaack!" etc...
I think that's what I'm seeing happen but just want to be sure this is correct behaviour.
RL
Post by RL » Fri Feb 23, 2007 2:32 pm
You are right.
Yes, correct.
Unfortunately there's not enaugh space in the flash memory to re-load all banks. But you don't need a factory reset for all banks - any bank is OK.
Have fun,
Rudi
till
Post by till » Fri Feb 23, 2007 3:13 pm
Thanks Rudi !
Nice to see you are still doing a good thing even better.
Question:
will the old bipolar pitchbend range data used for the up and the down range if the patch is loaded to an OS 3.3 Voyager ?
And what happens the other way: sending a patch with different up and down range to an pre OS 3.3 Voyager? What will happen ? Will the up or the down range used for both ranges ?
I guess you found a way to make the old and new sound work on the other Voyager too.
BTW: what synth got different up and down ranges on pitch bend too?
I think this is a seldom found (and used?) feature.
RL
Post by RL » Fri Feb 23, 2007 5:04 pm
Yes, the Voyager checks the preset after loading and changes the value to the new pitch bend up/down location in the RAM.
Older OS versions will ignore the new pitch bend up/down values - sorry.
Have fun,
Rudi
earsmack
Post by earsmack » Fri Feb 23, 2007 7:07 pm
Thanks Rudi
I think I nuked a bank by accident but I'll just download some of the patches from the web site and reload. I saved my own bank of patches properly which is good! What's the easiest way to get A-G reloaded fully? I forget how they got there initially -I guess since I bought a 3.0 unit they were there all along.
Thanks again - I like the new save functionality!
RL
Post by RL » Fri Feb 23, 2007 8:11 pm
Ask Amos from Moogmusic - I'm sure he can send all banks to you.
I'm using the editor software for storing the banks.
Have fun,
Rudi
Stuckinabox
Post by Stuckinabox » Fri Feb 23, 2007 8:13 pm
I also really like the new save interface.
However, the best part is the nonsense that got loaded into the compare buffer. It's a bunch of bizzare settings that I have yet to figure out (I got back to normal from the original patch) but it's great for sound effects.
RL
Post by RL » Fri Feb 23, 2007 8:29 pm
Yeah, the new functions change the address of the compare buffer and this nonsense happens when you forget the factory reset.
Have fun,
Rudi
ssilk
Post by ssilk » Sat Mar 03, 2007 5:49 am
re: Voyager updates...
I'm not (yet) a Voyager user (though I'm hoping to be the proud owner of an LP Stage Edition once they're available!), but there's something about the Voyager functionality that I've been wondering about:
would it be possible in a future update to add a feature supporting the "analogue mode: pass-thru / track" functionality that the LP has? or does the hardware used on the Voyager simply prohibit such an addition to the OS? it seems like it would be a useful touch, I'm surprised that the Voyager doesn't support it already...
keep up the good work, moogers!
~S
RL
Post by RL » Sat Mar 03, 2007 6:01 am
Yes, I guess we will get this function in OS 3.4
Have fun,
Rudi
