Some questions
sergio
Some questions
Post by sergio » Sat Apr 24, 2004 12:37 pm
I have updated my Voyager Os to 2.1 version.
Everything worked fine but I don't understand why when I switch it on ,the sound that is displayed on the lcd appears with the "*" symbols like when a parameter has changed.It is normal???
Another question
How can achieve perfect tuning with the fine tune knob??
Bye
Sergio
sir_dss
Post by sir_dss » Sat Apr 24, 2004 1:10 pm
The * * is there to let you know that you made a change in case you
* * want to save it.
...and does you heart have perfect pitch yet???
sergio
Post by sergio » Sat Apr 24, 2004 3:07 pm
I know this but the sound appears with the ** when I switch the Voyager on without touching any knob
sir_dss
Post by sir_dss » Sat Apr 24, 2004 4:40 pm
Wow...Yours must be broken.
TonyR
Post by TonyR » Sat Apr 24, 2004 8:23 pm
Maybe try turning the voyager off on a non edited preset. The Voyager powers on with the same settings as it held before power down.
StefanH
Post by StefanH » Sun Apr 25, 2004 9:12 am
This must be the reason.
If you turn off voyager after you edited a sound and didn't saved it, he will return to this sound after turn it on again. But i must agree, i had also sometimes *...*, even when i was not touching any knob....? Midi-In Signals also change the sound, so check if there are some signals going thru.
