I've read the procedure in Lord of Modulator to minimize original tones bleeding through.
I didn't open the pedal to trim VR1 as I don't hear "when a short note is played, the carrier die out about two or three seconds later."
So I guess VR1 is correctly trimmed ?!
Now, when I put a jack in Carrier IN socket (nothing plugged on the other side), I can still hear the incoming signal modulated by the internal Carrier...
The internal carrier is always a little bit in action ?
Anyone has a clue ?
(Hope VR2 reduces that !)
MF-102 RM : Carrier Bleeding Trough ?
Voltage Controlled Dilettante
Re: MF-102 RM : Carrier Bleeding Trough ?
Hello,StereoH wrote: The internal carrier is always a little bit in action ?
All analog ring modulators have some carrier bleedthrough.
The only ring mods that completely suppress the carrier signal are the digital type.
Regards,
Lawrence.
