M-101 Low Pass into High Pass with CP-251?
i have a few different sound processors with phase inverters, and i've been trying to aproximate this patch on my mackie mixer.
although i have been getting some unusual filter responces, i haven't been able to get anything close to a high pass filter response.
So, I think this idea might be a little difficult to execute in the real world. but, i'm sure the processors i'm using are not ideal...
Its going to take more than just phase inversion to get it to work as a highpass filter. The phase shift must be frequency dependent, thats why an allpass filter is needed to track to the lowpass filter. It may work somewhat when the cutoff is at a certain frequency, but it won't work if you want to change the cutoff frequency.
When you subtract these two filter's outputs the phase shift causes the lower frequency to cancel leaving only the high frequencies. This is why it must be subtracted from an allpass filter, the phase shift caused by a LPF varies according to the input frequency. That means a signal at frequency A will have a different phase delay than a signal at frequency B. An inverter has a constant phase shift of 90 degrees over the entire frequency spectrum, not the varying phase shift needed. An allpass filter passes all frequencies equally, but with an varying phase shift.
Also, keep in mind that the user is going to want to change the cutoff frequency of the LPF. Therefore the allpass filter must track to this cutoff change to cancel properly.
I couldn't find much on the internets about the phase cancellation I was describing, but check out this neat little diagram I found. Its shows a discrete signal, but the basic idea is the same.
The mixer in the CP-251 has sufficient bandwidth for processing audio signals, and can be used as a simple audio mixer. But watch out for DC offset (the Mixer's Offset control), as this will add a DC component to the Mixer Output signal (AC). A DC offset can have a negative effect on audio circuits that the Mix Out signal is routed to.Impossible Sound wrote:I used an external mixer to combine the signals, but the CP's mixer works fine for audio - I don't get any clicking.
-G
What HPF did you choose?Impossible Sound wrote:I've since added a real HPF to my rig, so there's no more need for this tomfoolery.
Sub Phatty, MF-101, MF-103, MF-104z, & MF-105
http://www.earth2willi.com
