I just got an MG-1 and so far it's a mixed blessing. My nerves were steeled to get inside and clean out the notorious Black Muck, and lo and behold, there wasn't any! At some point in this unit's lifetime, somebody took out the foam before it got bad. There wasn't even any post-cleanup residue. For anyone who's ever undertaken this task (I did an Opus 3), you know this is worth about two hours of your time, not to mention a lot of Q-Tips.
So much for the good luck. On the down side, it seems one of my MM5823 divider chips is going south. At first I thought it might be some of the trigger buss contacts because I could get the dead notes to sound by keeping a lower key pressed. But on closer study of the schemo, I found that all the triggers are extracted AFTER the polyphony summer. This means anything that goes wrong with those divider chips will affect the behavior of the whole keyboard.
So, here come the questions: What is the deal with these chips failing? Why do they go bad? Is it the chip itself that's unreliable or is it a design problem? By design problem, I mean I wonder if there's some sort of circuit modification that might help protect these chips from future damage. If not, it seems like a losing battle with any keybaord that uses the MM5823, because eventually they will all fail, and eventually there won't be any left to replace them with.
Anyone have thoughts/ideas/suggestions on this? Thanks!
Regards,
Joe
