how does a 12 stage phaser compliment the low pass filter?
Spank
Post by Spank » Sat Jul 29, 2006 10:21 pm
anyone here have both and use both of them at the same time? i'm just wondering how both of these two react in a way that would suit most people. i'm into electronic/synth music and i can already get a nice sound out of the LPF but what can i do with a 12 stage phaser along with an LPF?
godzilla
Post by godzilla » Sun Jul 30, 2006 9:22 am
you could use the lfo on the phaser to modulate the filter
use the env follower to modulate the phaser
use the env follower to modulate the speed of the lfo then plug that into the filter
take off the high end to make the phaser sound more mellow
there is a huge number of things you can do with any combination of different moogerfoogers
analoghaze
Post by analoghaze » Sun Jul 30, 2006 5:38 pm
The sound great together. I like having the stereo outs on the 12 stage.
Spank
Post by Spank » Mon Jul 31, 2006 12:09 am
i hear you can get that 'classic moog filter sweep' by using both the phaser and the filter. is this true?
asd
Post by asd » Mon Jul 31, 2006 2:05 pm
I assume that the "classic sweep" is just using the lfo to modulate the cutoff frequency so the 102, 103 or 251 could do this (it looks like Godzilla mentioned this above). Check out your other thread about using an lfo with the 101 too.
Spank
Post by Spank » Fri Aug 04, 2006 10:26 pm
would the phaser strengthen/improve the filter sweep? what about a ring mod?
