FRONT
(if pic isn't loading, go here)
BACK
Stuff that might be confusing:
-Envelope. I spent a while considering how to fit an ADSR into the fooger design without getting too weird or extravagant. Personally I'd be totally fine with just an AR env (sustain is 100%). The parameters are straight off the voyager.
- Audio IN: hardwired to the osc freq mebbe? a guitar/bass/drum/voice synth would be fun.
- GATE IN: Connecting this to a TRS cable would disconnect the osc from EG (or whatever keeps the osc in drone mode) until a gate trigger signal is received.
- no VCA? I'm presuming this would be built into the drive feature, so that the AUDIO IN could be be used in conjunction, and then the mix knob could be used to wet/dry between OSC and whatever is being input.
Discuss. (Moog, I hope you're lookin' too!)
