which modular
godzilla
which modular
Post by godzilla » Mon Jun 12, 2006 3:49 am
hey guys i've got the 104SD, I'm getting the LP
and after that i'm going to pick up some more foogers
but eventually i will be getting a modular system of some kind that incorperates some of the thigs that moog don't make like a sequencer (unless they come out with one by then)
my question (just so i can plan ahead) is this:
which modulars work best with the moogerfoogers/other moog gear?
and this can come under technical things like voltage ranges
or things that have more to do with sound, looks, build, value e.t.c.?
thank you
sir_dss
Post by sir_dss » Mon Jun 12, 2006 4:31 am
MOTM(Synth Tech) without a doubt. I have a 4 VCO system that I use with my Voyagers, all the filters except the Triple Resonant Filter and all the fixin's(EG's, VCA's, S&H Noise, etc...)
I also just fo the 650 Midi to CV modual as well.
Paul's system sounds incredible and well designed. It's also really roadworthy. I've toured the states with it. DID I SAY IT SOUNDS GREAT ABOVE ALL.
I do also have some Blacet moduals that i converter to the MOTM standard(MiniWave, Time Machine, Binary Zone, Dark Star Chaos)
eric coleridge
modulars
Post by eric coleridge » Mon Jun 12, 2006 7:33 pm
the synthesizers.com modular looks pretty nice too, and is significantly more affordable. It's also designed after the original Moog Modular with many similar modules.
I think you'll find most any modular is compatable with the Moogerfoogers.
MarkM
Post by MarkM » Mon Jun 12, 2006 9:31 pm
The dotcom sequencers look good. That smaller one (500 series) for about $550 looks enticing. Other than a power supply, is that all one would need to sequence the Voyager (outfitting with the VX351)?
Mark Mahoney
www.cdbaby.com/cd/markmahoney
