i just ordered the moog analog delay? 2 questions.
Can the voodoo lab power supply, power this pedal, or would that mess up the pedal.
will any brand of expression pedal work with the delay pedal?
question about the delay pedal
- latigid on
I think the pedal power has special red plugs that reverse the polarity (MFs need +9VDC at the tip). If you don't have these, you can make your own (radio shack).
Most brands of expression pedal should work with Moog pedals. It needs to have a 50/100kOhm pot in it, which you can check with a multimeter. Check the manual for more details, and to see if your pedal is wired correctly.
