Sub 37 note pitch issue
Everything Sub.
funk4life8
Post by funk4life8 » Sun Apr 02, 2023 2:31 pm
My Sub 37 won't hold a note for certain patches that are a single pitch. It sounds like someone is turning a pitch wheel. It happens somewhat randomly with the same settings, not pressure, etc. I updated the firmware, didn't help.
You can see the video below. The pitch issue happens on and off for 30 seconds, then at 33 seconds it comes in and clearly pitch bends what should be a single pitch:
https://drive.google.com/file/d/1ZoKDiW ... sp=sharing
ruthjackson
Re: Sub 37 note pitch issue
Post by ruthjackson » Wed Oct 04, 2023 5:00 am
Hello, I think you should check the pitch bend wheel. Ensure that the pitch bend wheel is centered and not accidentally being triggered. Sometimes, if the pitch bend wheel is not in its neutral position, it can cause unintended pitch modulation. Try moving the pitch bend wheel up and down a few times to make sure it's returning to its centered position accurately.
Pistons
Post by Pistons » Tue Sep 16, 2025 10:04 am
I had a similar issue and followed these steps ; the pot calibration solved the problem for me
https://moogmusic-help.freshdesk.com/en ... hatgpt.com
