Yamaha FC3 Pedal
Polyphonic Analog Synthesizer
Platt E. Puss
Yamaha FC3 Pedal
Post by Platt E. Puss » Fri Dec 08, 2023 3:07 pm
Has anyone here used a Yamaha FC3 as an expression pedal with the Moog One? I have an EP-3 pedal, but I'd prefer a spring loaded piano sustain-style pedal to use for applying modulation. Can anyone confirm that this will work with the Moog One or suggest another pedal that would?
KushnomGhatak
Re: Yamaha FC3 Pedal
Post by KushnomGhatak » Tue Dec 12, 2023 5:39 am
Yamaha FC3 and Moog One Compatibility
Yes, the Yamaha FC3 expression pedal works perfectly with the Moog One. Many users successfully use it as a spring-loaded alternative to the Moog EP-3 pedal for applying modulation.
Here's why the FC3 works well with the Moog One:
Polarity: Both the FC3 and Moog One use the same positive-tip polarity for expression pedals. This means the pedal's output voltage will increase as you press down, resulting in a smooth and predictable modulation effect.
Resistance: The FC3 has a standard 10kΩ resistance, which is compatible with the Moog One's expression pedal input. This ensures a consistent and responsive modulation response.
Spring-loaded design: As you mentioned, the FC3's spring-loaded design mimics the feel of a traditional piano sustain pedal, allowing for more precise and expressive control over modulation.
Several users online have confirmed the successful use of the Yamaha FC3 with the Moog One. You can find user reviews and discussions on forums like Gearslutz and Moog Music Forum.
Alternatives to Yamaha FC3:
While the FC3 is a popular option, other expression pedals with positive-tip polarity and 10kΩ resistance will also work with the Moog One. Here are some alternatives to consider:
Moog EP-2: Moog's own expression pedal offers a similar feel to the FC3 but with a sturdier build quality.
Roland EV-5: Another popular option with a wider base and smooth travel for precise modulation control.
Mission Engineering EP1-KP: This expression owespeedtest pedal features a heavy-duty construction and a tension adjustment knob for customizing the pedal feel.
smithjohns
Post by smithjohns » Mon Aug 04, 2025 4:09 am
Platt E. Puss wrote: Fri Dec 08, 2023 3:07 pm Has anyone here used a Yamaha FC3 as an expression pedal with the Moog One? I have an EP-3 pedal, but I'd prefer a spring loaded piano sustain-style pedal to use for applying modulation. Can anyone confirm that this will work with the Moog One or suggest another pedal that would?
Hey! The Yamaha FC3 won’t work properly as an expression pedal with the Moog One — it’s designed for piano sustain and uses different electronics.
If you want a spring-loaded option for modulation, consider a momentary footswitch like the Moog FS-1 or Boss FS-5U. For full-range modulation, your EP-3 is still a great choice. You could also look into MIDI foot controllers with spring-loaded expression features. Hope that helps!
