Constantly sending CC 43 out
MOOG MESSENGER - All thinkgs Messenger! The next-generation analog synthesizer from Moog.
hollarob
Post by hollarob » Fri Jul 11, 2025 5:21 pm
does anyone has the issue of the Messenger constantly sending out MIDI CC 43?
The out value is either 0 or 8. A factory reset did not work.
Firmware: 1.0.7
Cinebulle
Re: Constantly sending CC 43 out
Post by Cinebulle » Sun Jul 20, 2025 6:25 pm
Hi ! Did you solve the issue ?
I have the same issue, but with many CC numbers constantly changing when i do nothing... IF i connect it in USB. In DIN Midi it works fine...
hollarob
Post by hollarob » Mon Jul 21, 2025 3:44 pm
Hi, no unfortunately I did not. And the CC 43 issues still happens with DIN. Does it happen on you Messenger also with DIN?
I have 4 tickets open with the Moog support. You should too, so they know that there is demand for a fix.
Cinebulle
Post by Cinebulle » Fri Jul 25, 2025 3:39 am
It happens in USB not in Din. But if The usb câble is connected, It happens also with Din !
Yes I have a ticket with Moog…
hollarob
Post by hollarob » Sat Jul 26, 2025 7:51 am
Okay, for me it definitely happens also with DIN - check your settings and setup, if it's filtered out somehow, maybe by the MIDI hosts.
