Hi to all,
As the title suggests, it appears my Messenger won't send midi program change messages to my Waldorf Blofeld...although the Blofeld does receive the programe change messages sent from my Akai MPK225 controller.
In both cases, I have used a conventional 5 pin midi cable.
Can anybody help???
Thanks a million!
Midi program change issues
Re: Midi program change issues
Confirm setting to send program change send/receive:
SETTING -> Config (PGM 16) -> Page 3 (48) -> PGM 2 (Program Change) ->
PGM 1 Lit Send is ON, PGM 1 Off Send is OFF
PGM 2 Lit Receive is ON, PGM 2 Off Receive is OFF
Also, confirm the MIDI I/O settings in: SETTING / Config, Page 3, Parameter 4
Confirm these settings are set to allow MIDI Out to DIN or Both ( PGM 8 )
I can confirm, that after these settings are set, the Moog Messenger indeed sends Program Changes.
Live Setup:
Nord Stage 4, Moog Subsequent 37, Moog Messenger, Korg multi/poly, Hammond MSolo
Thanks a million, will try this ASAP!
Shouldn't program change be enabled by default, though?!
