Grandmother oscillator pitch input calibrate
TinyVince
Post by TinyVince » Wed Mar 26, 2025 12:07 pm
Hallo
Exist a possibility to calibrate both patchpoint exactly to volt per octave ?
In my case bot osc run around 15 cents down from c3 to c4 as example.
Thanks for support
TinyVince
Re: Grandmother oscillator pitch input calibrate
Post by TinyVince » Thu Apr 10, 2025 2:03 pm
Do any users have the two PitchIns working properly in the V/Oct standard or does it have to be that way that this is not the case and cannot be recalibrated?
sdwillingham
Post by sdwillingham » Sat May 03, 2025 2:04 am
I’m sure there is no built-in calibration for this. You would need to alter the summing resistors in the circuit so that the external patch points were matched with the internal pitch CV path.
