Muse Filter Keytracking
MOOG MUSE - All things Muse! Eight-voice analog bi-timbral polyphonic synthesizer
Kwamensah
Post by Kwamensah » Fri Nov 29, 2024 1:12 am
Hi, has any one else noticed that the 1:1 key tracking on the Muse is way off? Like if you self oscillate the filter and set it to 440hz with 1:1 it's not in tune at all and doesn't track across the keyboard. And if I tune it to the key I press, the scaling of the keytracking is off.
Is this just me or is it maybe something that will be fixed in firmware? Or is there another solution?
steve_moog
Re: Muse Filter Keytracking
Post by steve_moog » Fri Nov 29, 2024 11:00 am
Kwamensah wrote: Fri Nov 29, 2024 1:12 am Hi, has any one else noticed that the 1:1 key tracking on the Muse is way off? Like if you self oscillate the filter and set it to 440hz with 1:1 it's not in tune at all and doesn't track across the keyboard. And if I tune it to the key I press, the scaling of the keytracking is off.
Mine is decent. Have you run a full calibration?
Guest
Post by Guest » Tue Dec 10, 2024 11:52 pm
steve_moog wrote: Fri Nov 29, 2024 11:00 am
I did do both a full tuning, and full auto cal and still the key tracking on the filter is off, and strangely it's off by different margins between the two filters so there's definitely something going on with the calibration or control of the filter key tracking.
SoundQuest
Post by SoundQuest » Tue Dec 17, 2024 3:48 pm
Mines working fine.
Guest
Post by Guest » Wed Dec 18, 2024 12:31 am
Keytracking is still out for me, + or minus about 20 cents on each end of the keyboard.
Guest
SoundQuest wrote: Tue Dec 17, 2024 3:48 pm Mines working fine.
Are you checking it with a tuner?
Guest
Post by Guest » Wed Dec 18, 2024 1:41 pm
Plus or minus 20 cents across the keyboard is likely within spec. Self-oscillating filters are generally not precisely pitch tracking analog circuits. (If that was easy, we would see a lot more analog sine-wave oscillators.)
sdwillingham
Post by sdwillingham » Wed Dec 18, 2024 1:42 pm
(Accidentally posted that last reply without logging-in…)
Kwamensah
Post by Kwamensah » Wed Dec 18, 2024 9:12 pm
sdwillingham wrote: Wed Dec 18, 2024 1:42 pm (Accidentally posted that last reply without logging-in…)
So I just ran a new auto cal and tuning cycle today (first since the update) and it keytracks perfectly now!
Guest
Post by Guest » Wed Jan 15, 2025 8:58 pm
Kwamensah wrote: Wed Dec 18, 2024 9:12 pm
Yeah I have no way to prove it but I think they tightened up the tolerances somehow on the calibration, mine sounds great too.
