I have the moog matriarch and the delay seems to be working (e.g., there is a delay which is activated when I turn up the mix and the feedback) and the time knob is changing the delay time, however, the led is not blinking to the appropriate rate... (this is true with its own internal clock and external clocks like USB and midi. Instead, when its is clock synced via USB, the LED just stays on the the entire time without blinking and when it is using it's internal clock, the led flickers but very very fast (Importantly, the LED flicker does slow down a LITTLE -- but is still VERY fast -- when the time knob is turned up)
What is wrong and how can I fix this?
