2016 re-issue Osc 1 problem
I have a 2016 model d re-issure. Was working great. Now OSC 1 just stopped working on lower keys when set to lower range, and on the upper keys/high ranges it sounds "sickly", kind of wavering in tune and distorted. But OSC 2 & 3 sound normal. Anyone else have this problem?
Could it be a dirty range switch.
I have done a forum search , but not many popped up , and ones that did have had no resolves.
Any pointers will help.
Thanks.
Thanks.
- RL
Re: 2016 re-issue Osc 1 problem
replace C1 (10nF mica or polystyrene flex)
Have fun!
Have fun!
http://www.moogmusic.de
Thank you.
Sorry only just picked this up.
Hope it works for me.
Okay so far so good. Replacing C1 on Osc pcb has worked ( 22 May 2024 ).
Thanks for the tip by RL.
Cheers and lets hope this work for a long time.
OK i know its only been 2 days since i changed C1, but the mini Ocs 1 is still in tune from switch on.
I'm well pleased because i have no Tech guy to fix it around here. I have a small amount of electronic
knowledge but was able to do this easy fix.
Hope by putting this up here others will benefit.
It would help if I had known this in 2017trontastic wrote: Fri May 24, 2024 12:20 pm OK i know its only been 2 days since i changed C1, but the mini Ocs 1 is still in tune from switch on.
I had exactly this problem and unfortunately had to send the entire device in for warranty service at the time, but good to know. Thanks anyway.
mod d 2017 muse, sub37, minitaur, mf101, mf102, mf103
- RL
dann war dein Mini schon einmal auf meinem Platz - ist doch gut
Oh schau an - dann bedanke ich mich nachträglich gerne noch direkt!
Das Teil erneut auf die Paketreise zu schicken war schon aufregend - aber ging ja gut
