My new Moog One v. 1.5 seems to have been working fine, but today I tried exporting for the first time. When I export "All Data" it works fine. When I try to export "Presets" this causes the unit to soft-reboot without completing the export. After the aborted export of presets, there are about a dozen presets on the USB, when there should be several hundred. USB has plenty of room, that is not the issue. I tried reformatting the USB drive and that didn't help, either.
I thought I'd post to the forum before contacting Moog service to see whether anyone else has run into this problem and/or is aware of a workaround?
Attempt to Export Presets to USB causes Moog One to Restart
Moog One 16, OB-X8, Prophet 10 Rev4, Osmose, Trigon 6 D, OB-6 D, Kawai VPC-1, Rhodes Mk8 FX, Steinway D, Mac-based Protools w/Carbon.
Re: Attempt to Export Presets to USB causes Moog One to Restart
Try exporting the presets in chunks (i.e select a subset at a time). I had to start doing this when I amassed over 1000 presets.
Original Model D, Taurus 1, Taurus 3, Source, Minitaur, Voyager RME, One 16 voice
Thanks for the suggestion, will do!
Connect the USB Drive Before Starting the Export: Ensure the USB drive is connected to the Moog One before initiating the export process.
Avoid Interrupting the Export: Do not disconnect the USB drive or perform any other actions that might interrupt the export process until it completes successfully.
Verify Exported Presets: Once the export is complete, check the USB drive to ensure all the expected presets have been exported correctly.
