Arp behavior
Arp behavior
Hi everybody,
maybe is a topic that already has been discussed of , but when i use the arpeggiator , it always start with a little delay from the moment i trigger the note . Has anybody noticed the same problem?
Re: Arp behavior
Do you trigger the note on the Moog keys or is the note triggered by a DAW (Midi)?
Moog One 16/Moog minitaur/NL C15/Waldorf Iridium/Prophet XL/Prophet 10 D/Prophet rev2 16/OB-X8/OB 6 D/2600/VC 340/Kurzweil PC3K7/Access Virus TI2/Reason/NI Ultimate/Logic X
Re: Arp behavior
And what sync settings are you using?Do you trigger the note on the Moog keys or is the note triggered by a DAW (Midi)?
Re: Arp behavior
Of course i am triggering the note on the keyboard and no daw is opened . And on the receive midi clock, i tried off, din and usb but nothing changes . There is still a delay
Re: Arp behavior
Yes, I am seeing the same thing. Even with sync off.
It is easily tested by doing the following:
1) Turn on Arp and open Arp page
2) Turn Sync off
3) Set the note division to long note like 1/2
Unless you get very lucky hitting a key will sound quite noticably after you strike the key.
My guess is that this happens because even with sync off, the arpeggiator is using a clock to decide when to fire notes off, and the clock is not getting reset to 0 when you hit a note.
And, I just figured out the solution: go to the next row and turn on Note Reset. That will reset the clock when you hit the first note. Let me know if that works!
2) Turn Sync off
Re: Arp behavior
Try the following:
1.) Init a sound with Shift+Compare
2.) Switch ARP to On
In the ARP Menu:
3) Switch SYNC off
4) Set CLOCK DIVISION to 1
5) Set GATE LENGTH to 1 %
6) Set NOTE RESET on
7) Set FOLLOW SWING OFF
Play some notes an the Moog keys (1/8 notes e.g.)
8.) Turn SYNC on
Play some note in the same speed as before.
Switch SYNC on/off while you are playing some keys.
There is a difference.
With SYNC on play a note and hold a key, repeat this.
Is this the delay?
In the ARP Menu:
3) Switch SYNC off
8.) Turn SYNC on
Is this the delay?
Re: Arp behavior
I see this behaviour when the ARP clock is synced (delayed start of ARP after pressing a key).
I see a similar problem in the Sequencer when triggering the sequencer with a key. More often than not, the first note of the sequence is missed. If I press start in the sequencer, it is fine. Start with a key press...not fine.
I have reported this to no avail.
Re: Arp behavior
Just out of curiosity: which synth are we talking about here? I realise this is an old thread, but I am experiencing exactly the same problem with my Moog Grandmother and was wondering if anyone has found a solution
