Look at the manual to see its features and way of working. Then decide to purchase it or not for a small amount (it is also including presets from the 3 patch books).
https://www.sunnysynths.com/moog-matriarch
The panel is only a patch loader/saver on computer as the Moog Matriarch does not support the load/save of programs by sysex dump exchange. It supports however the manipulation of some program parameters by Midi CC messages but far from all parameters are covered. It also handles global settings management by sysex messages.
Features:
Moog Matriarch patch saver/loader for PC and Mac
Displays all patch points from the main synth panel but also all outputs from the rear
Button to switch the layout between the colored and the Dark editions
Bidirectional communication with actual Matriarch synthesizer for all parameters supporting CC# Midi communication (pages 18 and 19 of the Matriarch v1.2.3 Firmware update manual)
Top row of support “screens” with old look
Visual feedback by using “LED” ring buttons and indication of the parameter value
Envelope graphs handled by mouse or classical ADSR rotary encoders
Load / Save programs from individual .syx files
Automatic change of all CC# parameters on actual synthesizer at program load
Program settings management (a selection of Global settings but stored at program level)
Global settings management (receive all then individual update)
Easy program renaming
Display and export of program parameters as text file
Ability to describe 15 input/output colored patch cables with different sources/destinations
Programs have a name, author, save date and description. They can be associated to a category
Ability to describe the usage of each program in a step by step mode (up to 15 steps)
Browser of the files on the disk
Patch sheet tab with patch sheet for Matriarch and other gear
Patch cables (15 colors)
Author and save date
External synths and FX chain
Display of current precise parameter value when clicking on rotary encoders
Memorized panel zoom
Automatic reading of wav files associated to a patch
Manual/Automatic reading of any wav file
Standalone versions for PC and Mac
VST versions for PC (32 and 64 bits)
VST and AU versions for Mac
Extras Midi CC controller number for the buttons without a Moog assigned number so you can adjust them from a hardware controller (still no impact on the synth of course and unfortunately).
