Sequenzer Mode - ony 1 note adjustable against the hint in the manual
Polyphonic Analog Synthesizer
deboje
Post by deboje » Sun May 16, 2021 12:03 pm
Hi erverybody, I just purchased my first Moog one (16) and being exploring through everything. In the manual is written that using the sequenzer I should being able to select multiple notes.
There is written:
Pressing the ROW UP button until it reaches the the current Step number will highlight and select all of the Notes on the current step.
But if I do so, only the selected Note will still remain adjustable not all at ones.
Has anyone the same behaviour or am I the only one?
Thank you for your advie
regards
chefmenteur
Re: Sequenzer Mode - ony 1 note adjustable against the hint in the manual
Post by chefmenteur » Mon May 24, 2021 4:35 pm
I was able to delete all notes in a step using the process described. What operation were you trying to do?
