New Matriarch Global Settings Editor
mreid
Post by mreid » Fri Oct 09, 2020 5:33 am
Hi everyone,
Thanks to the new v1.2 firmware update that enables global setting editing over SysEx, I was able to build a simple Matriarch settings editor that runs in your browser using a JavaScript MIDI library.
You can try it out here: https://mreid.github.io/matriarch-editor/index.html
There are instructions on how to use it on the same page as the editor.
I hope some of you find it useful.
Jobinho
Re: New Matriarch Global Settings Editor
Post by Jobinho » Fri Oct 09, 2020 6:58 pm
Thanks for taking the time to create this, I know a lot of us will be very grateful!
Markyboard
Post by Markyboard » Sat Oct 10, 2020 7:57 am
Fantastic! I was concerned at first that it wouldn't work with my DAW (Reaper) open at the same time. But it's just a matter of disabling the Matriarch track so that it can recognize the USB or midi ports . I guess it's not multi-client? Not a big deal as this is so much better than manually configuring the globals. If someone comes up with a VST version that would be even better. Until then I'll be using this.
Thanks and well done!
hudri
Post by hudri » Sun Oct 11, 2020 3:56 am
Hi, looks good!
You do also know about my standalone program MatriarchSwitch?
mreid
Post by mreid » Sun Oct 11, 2020 8:40 pm
Hi hudri,
No, I hadn't seen that. Looks great!
Being able to save settings is a really useful feature. And the parameter descriptions are nice too. I'm hoping to add similar things to the one I wrote when I next get a chance.
Regards,
Mark
hellleutel
Post by hellleutel » Mon Oct 12, 2020 3:02 pm
Hello! First post! :)
This looks so great.
I'm on a Mac with Mojave and I can't get it to run with neither Firefox or Safari, although I've installed the API extension... it always says "MIDI-Out: Cannot find Matriarch! MIDI-In: Cannot find Matriarch!"
Before I try much further, has anyone succeeded with this configuration?
mreid
Post by mreid » Tue Oct 13, 2020 4:20 pm
Can you try Chrome? I found it to be the simplest browser to set up for this. No plug ins required, it just pops up a prompt asking for access to your machine’s MIDI ports.
Also, maybe check that the MIDI ports for your Matriarch have the word “Matriarch” in them. The editor currently assumes that. You can check the name using the Audio MIDI Setup app on your Mac.
bichuelo
Post by bichuelo » Tue Oct 13, 2020 8:00 pm
For me, it works on macOS High Sierra on Firefox, Chrome and Opera.
Only the latter loads the defaults from the synth, and Firefox is the only one which doesn't bring a pop-up asking for permission to use MIDI ports
http://audiotecna.info
MrBlue
Post by MrBlue » Wed Oct 14, 2020 2:06 pm
Works with the Brave browser... :wink:
Music is emotion suspended in space and time
illustrasons
hellleutel
Post by hellleutel » Wed Oct 14, 2020 8:03 pm
aaah yessss using Chrome seems to do the trick thanks a lot
dazeja
Post by dazeja » Wed Jan 13, 2021 4:27 pm
Thank you for this! This saved me, since my Matriarch for some reason decided to stop saving Global setting edits manually. I used your editor to make changes as well as troubleshooting the fact that it is not working. I'm trying to contact MOOG now. If I didn't have this I would be out of luck make changes.
chapelier fou
Post by chapelier fou » Thu Jan 14, 2021 11:21 am
did you try a Global resets ?
Enter Globals with HOLD + SYNC ENABLE then hold the highest black key and hit the lowest black key (on 1.2.3)
raucous66
Post by raucous66 » Sat Apr 24, 2021 9:30 pm
This is the greatest thing since sliced bread - 4/5 **** !!! 8)
But I did have one issue, when I had Ableton 11 and Push2 running with all 16 midi devices enabled for in and out, including the Matriarch, and after I loaded the Matriarch Global Settings Editor page and accepted the midi popup, like half the midi channels in Ableton started showing up as orange, and I couldn't get anything to work.
But it was a simple fix, I just saved my Ableton project and rebooted, lol!
My recommendation is to close the project you are working on, if Ableton 11 on PC (Win10).
I'm using Chrome btw.
Thanks,
__e
music@techsture.net
Post by music@techsture.net » Mon Apr 26, 2021 11:27 pm
Thanks mreid, this is great!
chapelier fou
Post by chapelier fou » Thu Apr 29, 2021 5:40 am
@mreid :
Would it be possible to simply save configurations to the computer ?
That would be awesome.
