Voyager XL - mono output only for some filter modes
- David Smyth
Hi there,
I have noticed recently that when using my Voyager XL in stereo (using 2x jack outputs, or headphones from the headphone output), the signal will cut out to one side only depending on the filter mode (dual LP = one side only, LP/HP = both sides).
I understand different filter modes give a stereo effect however I thought if there was a lack of stereo effect, both sides (L & R) would equally carry the same mono signal. The documentation isn't immediately clear to me on this.
Is this usual behavior or is there some servicing required?
David
NZ
David
NZ
Minimoog Voyager XL, Little Phatty Stage II + CV Output Mod, 2x Slim Phatty, Minitaur, MP-201, EP-2, 2x CP-251, MF-102, MF-104M, MF-107
Re: Voyager XL - mono output only for some filter modes
only thing I can think of is the "spacing" control, if you have it set extreme L/R it can cut the volume, depending on the patch
but if it's set in the middle, that should not happen
maybe twiddle the spacing knob a bit, could be dirty/defective?
- David Smyth
Cool thanks - I'll experiment with the filter spacing control for the patches in which it happens and report back.
I just messed with mine for a bit:
-spacing
-filter cutoff
-amount to filter
knobs all interact significantly, and I could lose one stereo channel easily by adjusting them. hopefully that's all it is?
good luck!
-spacing
-filter cutoff
-amount to filter
good luck!
- David Smyth
Thanks for taking the time to run tests and provide tips - I appreciate it!ummagumma wrote: Mon Jan 27, 2020 7:32 pm I just messed with mine for a bit:
-spacing
-filter cutoff
-amount to filter
good luck!
I have been experimenting further however it still seems not right to me. Regardless of filter cutoff, spacing, and amount to filter control positions, I found the following:
When playing a note in highpass/lowpass filter mode, there are two signals, as you'd expect, however with more signal detected on the left side. The left signal is stronger than the right according to my DAW by about double (visually only) in terms of the meters.
(I'm not sure if this skewed stereo signal is a good/bad thing or by design - I've been told when recording digital stereo piano not to worry about one side dominating with respect to signal strength).
When switching to dual lowpass filter mode, the right side's weaker signal remains but the left signal drops to very very minimal levels. You can only just hear the isolated left side when you crank the monitors and synth up. If you pull out the right side jack output cable, the right's signal is summed to the left side for mono output, hence why I haven't noticed this too much - I have been using the synth with a mono output for the past while. When compared to the strength of the left side signal in first scenario I described (highpass/lowpass filer mode), it doesn't seem ideal, or to be working correctly.
I'm not sure the spacing is working either.. I'm finding it hard to notice any difference with it in any position. Seems dead and possibly related.
To confuse matters slightly further, I'm pretty sure my XL headphone output's Left and Right are wired backwards from the main output's Left and Right jacks. Is yours this way? Do you think it is like this for on stage monitoring (facing the crowd) or an error in my unit's assembly?
Anyway, I'd say something is up with the filter section and/or vca(s) circuits maybe, and they might need servicing.
I'm keen to hear any opinions on these issues.
David
spacing should have a dramatic effect, when you pan it
if you enable the visual feedback in the display, can you see the values changing as you turn the knob?
ps set filter cutoff to around noon
- David Smyth
Yea I have the visual feedback on in the display and the values do change, but there is no difference in sound. I have tried this with the filter cutoff in various positions. Therefore I believe it's not working correctly, along with my filter mode issue.ummagumma wrote: Tue Jan 28, 2020 1:16 pm spacing should have a dramatic effect, when you pan it
ah, that sucks!
yes, appears to need a tech
as a hail mary, you could reinstall the OS & firmware
or open it up & try reseating cables etc
- David Smyth
Ah yes, I could try reinstalling the firmware - good idea! I've also contacted Moog Music tech to get their thoughts.
Will keep ya updated..
my XL has the same issue, were you able to fix it or locate the error?
Best regards
Moritz
Best regards
Moritz
Exactly same issue with my electric blue
I suspect the "famous" MUX problem, but I'm not sure.
> CHIP CD4052 U36 or U51 defect.
- David Smyth
Sorry I haven't been active in a while about this issue. I still have the problem and am looking at getting the unit looked at. Will keep you updated on any findings.
Hi!
I'm a new Voyager XL owner. I have a same problem. There's sound only one side (right).
Could you tell me please what is the solution for this?
Thanks,
Attila
Thanks,
Attila
