Chonky 1.4 has been released!
I’ve taken input from several users and incorporated these changes into Ver 1.4:
- Auto Load - automatically sync your data from your synth to Chonky on startup.
- Data Sync Status - Red / Green indicator showing if the data displayed in Chonky matches your synth.
- Quick Port Release - close and open all Midi ports with one button. Use this when running Chonky alongside other Midi programs.
- Midi Thru - loops your Midi-Out data back to your synth. Select this when using your synth in Local Off Mode.
- Midi Port Open Delay - configurable Midi Port Open Delay / Retry setting. This is helpful when using Chonky alongside other Midi programs that release their Midi Ports when switching applications (i.e. Reaper).
- Improved Midi Port Management - intelligent error management of Midi Ports. Useful when running Chonky alongside other Midi programs.
- Other cosmetic changes, stability improvements, and tweaks...
Thank you for all of your feedback and support.
A special thanks to Markyboard (Mark) for his input on functionality improvements and for helping me test!
Download for free at https://www.fuzzy-cat.com/
John
"Chonky" - Global Parameter Manager Software for Matriarch / Grandmother
Re: "Chonky" - Parameter Manager for Matriarch / Grandmother
FuzzyCat Software - Software tools for musicians - www.fuzzy-cat.com
"Chonky" - free global parameter manager software for the Moog Matriarch and Grandmother - www.fuzzy-cat.com/products
Thank's John
Music is emotion suspended in space and time
illustrasons
illustrasons
Chonky - 1.4.2 Released
Hi All,
I’ve updated Chonky to Ver 1.4.2.
Ver 1.4.2 Features:
• Matriarch firmware 1.2.3 - new Sysex parameter #74 support
• Bug fix - if you turned off or disconnected the Matriarch / GM prior to shutting down Chonky – Chonky gave you an error on exit.
• Improved timing - in sending data to the Matriarch / GM. Some systems were sending to the synth faster than it could handle.
• Other cosmetic changes, stability improvements, and tweaks...
Big thanks to Markyboard (Mark) on the Moog Forum and David Marks on the Matriarch Facebook Group for helping me test!
Click https://www.fuzzy-cat.com/products to download.
Enjoy!
John
Ver 1.4.2 Features:
Enjoy!
John
It works very well at home, thanks again to you, John.
Nicolas
Nicolas
illustrasons
illustrasons
"Chonky" - Updated to ver 1.4.8
Hi All,
I’ve updated Chonky to Ver 1.4.8.
Ver 1.4.8 Features:
• Feature - added Grandmother firmware version 1.1.3 new parameter #47 “Mult Trig Release Speed” support
• Feature - Chonky Auto-Restarts if there is a Midi error due to USB being unplugged or GM/Matriarch being power-cycled
• Bug fix - file save naming error when saving Grandmother sysex files
Big thanks to Pahlin (Pehr) and Markyboard (Mark) on the Moog Forum for helping me test!
Enjoy!
John
Ver 1.4.8 Features:
Enjoy!
John
Re: "Chonky" - Global Parameter Manager Software for Matriarch / Grandmother
Great !
Thank's John
Thank's John
illustrasons
illustrasons
