Always wanted a Moog-ish synth, got a Novation Bass Station 2 some years ago, liked it a lot, still something about the sound of the oscillators (DCOs) was unsatisfying. So I had to get me a Subsequent 25 right when it was released ... got #00027, sounds great
Some issues on the current version (firmware 1.02 / editor software 1.00):
1. When used with the editor software, the Fine Tune knob on the synth will stop working correctly. Instead, it will switch between a semitone flat (fully CCW) and a semitone sharp (anything above 08:00), with nothing in between. No way to tune the Synth correctly while connected to the editor. After unplugging the USB cable, you will need to restart the synth to make Fine Tune work correctly again.
2. Switching Legato Glide on/off in the software editor will have no effect. On the synth itself, switching Legato Glide on/off via hidden parameters does work fine.
3. I created a Patch where the Glide knob has no effect at all – neither the one in the software nor the one on the Synth. Not even after disconnecting from USB and restarting the synth. Or after saving the preset, storing it in the Librarian, reloading it into another preset slot of the synth. It's a fairly regular mono lead sound, with repeat on the Amp EG; but even switching Amp EG repeat off won't make Glide accessible.
Hoping this will be fixed in a future firmware/software version soon
