D reissue "drone" options
ummagumma
Post by ummagumma » Fri Nov 27, 2020 1:56 am
feeding +5v into the "gate" input on the back, keeps the oscillators running and works great for drones
it's a bit of a pain to always plug an external device in, to supply the +5v. Also if I bring the minimoog somewhere it's more crap to haul
So I was thinking, in order of least invasive options:
1. reading the manual, it says the OSC, VEL, FILTER external control jacks all supply +5v on the ring, to power expression pedals. So it should be possible to build a TRS-->TS cable that could feed +5v into the gate (?). Although it says it's current limited. which is probably a good thing. So all you need to do is plug that cable between them...disadvantage is, you lose a controller input on the D
2. drill a 1/4" hole in the back and wire it to +5v. So you could use any 1/4" cable, and also keep the external control jacks free
3. install a proper switch on the front. Lots of room, say over the headphone jack. It would look great if done with a matching Moog style switch. But square holes are a pain, and am not keen on modding the front of the unit
Anyone else have any thoughts? Is there another option, that could be easier, or less invasive?
thx
ummagumma
Re: D reissue "drone" options
Post by ummagumma » Fri Nov 27, 2020 2:04 am
I guess there is always option
2a. install switch on the back
although it may be useful to have a +5v tap, in the form of a jack instead
till
Post by till » Fri Nov 27, 2020 11:26 am
You may solder a special cable with a TRS into the Moog pedal in, a 1:1 connected female TRS socket for a pedal and another cable going into the Gate In with +5 V of the pedal socket. So you do not loose the pedal connectivity and don't have to modify your Minimoog Reissue. And if you like, put a switch in the cable to the Gate IN for switching the drone on/off without undoing and redoing a cable.
ummagumma
Post by ummagumma » Fri Nov 27, 2020 11:50 am
hey, that is an even better idea!!
thanks Till!
*edit* actually even slicker would be to make two male-to-female 1/4" jacks, plugged into the GATE and OSC, connected with a switch that feeds the +5v to the GATE. Then you could switch it on/off, and still use the GATE and OSC jacks as usual. Just leave the thing on there
if it's low profile enough, you could even close the lid flat
ummagumma
Post by ummagumma » Fri Nov 27, 2020 12:15 pm
hmm I guess no one makes anything like that...I was thinking something like this right angle TRS, with a "through" female connection if you plug straight in
https://www.fullcompass.com/prod/038167 ... io-adapter
image link:
*edit* I can't seem to find a stackable TRS connector, similar to the Buchla stackable jacks, either. Oh well, easy enough to just use cables
Markyboard
Post by Markyboard » Fri Nov 27, 2020 8:11 pm
Send a midi note on message without a midi note off message. I knew that one day those old versions of various software would be valuable. :mrgreen:
ummagumma
Post by ummagumma » Sat Nov 28, 2020 7:43 am
ha!!
:lol:
jdkJake
Post by jdkJake » Sat Nov 28, 2020 3:04 pm
Back in the day, for some of my synths, I used to use golf tees to hold down a particular key or set of keys.
Works great, easy to apply, easy to remove, easy to change.
—jk—
stiiiiiiive
Post by stiiiiiiive » Mon Nov 30, 2020 6:08 am
I do the same with the half of a clothes pin :)
ummagumma
Post by ummagumma » Mon Nov 30, 2020 10:53 am
ha, I suppose golf tee/clothespin/weight works as well. Or as Keith Emerson famously used, daggers 8)
advantage of using gate: you can transpose by just hitting whatever key you want to be in
thanks for the suggestions, all
hieronymous
Post by hieronymous » Tue Dec 01, 2020 10:22 pm
Steve Moore of Zombi just posted this on Instagram the other day:
ummagumma
Post by ummagumma » Thu Dec 03, 2020 6:10 pm
hey, I guess that is an easy way to do it, as well
free advertising for the cannabis delivery service too!
