1974 minimoog contour gen issue
my minimoog was relatively recently fixed up by a competent tech (basics like replacing caps, etc) and working perfectly fine for the better part of a year. i moved and didn't use it for a bunch of months and now the contour generator seems to have stopped functioning. i am a competent tech myself but the specifics of the contour gen have me a bit stuck. basically, the key trigger is working fine (-10V to 10V) but am getting 0V at the collector of Q20. i have replaced all of the transistors on the pcb with appropriate types, CR10 (which was cracked but functional) and a few carbon comp resistors. the only other slightly odd thing is that my 15V rail is a bit higher at just above 20V so that could possibly be contributing to the issue. any thoughts?
Re: 1974 minimoog contour gen issue
Are both contour generators not working? How about just the attack portion? I would check the decay switch and s-trigger input circuitry - It may be shorted. Try disconnecting and reconnecting the Cinch-Jones connector from the left hand controller.
i had checked the decay switch prior and it was ok. after plugging in again, Q26 (in the decoupling circuit) let out the magic smoke. i was using exact part replacements but purchased them from tayda a few years ago and after checking them out, the 3392 must have been rebranded because the pinouts did not match what they should have beenMarkyboard wrote: Sat Oct 10, 2020 4:58 pm Are both contour generators not working? How about just the attack portion? I would check the decay switch and s-trigger input circuitry - It may be shorted. Try disconnecting and reconnecting the Cinch-Jones connector from the left hand controller.
Cool- glad you resolved it.
