Model D Reissue tuning issue
FlavioB
Post by FlavioB » Sat Jun 13, 2020 4:00 am
Hi all.
Is it normal that the Model D Reissue looses the tuning along the scale (don't remember how that is defined, but you get 1 octave to be "almost" in tune, the octaves above/below are not)...
Any reports/feedbacks on this?
F.
till
Re: Model D Reissue tuning issue
Post by till » Sat Jun 13, 2020 8:36 am
Should not happen. Even after a longer period of months not used. No problems here. I would check the PSU first.
rpol
Post by rpol » Fri Dec 04, 2020 11:26 am
You've probably sorted this by now, but it sounds like it needs recalibrating - the procedure is described in the manual if I remember correctly.
