Sub 37 Panel Mode: Preset settings not persistent
Everything Sub.
fwilleke
Post by fwilleke » Thu Aug 01, 2019 3:13 pm
Hello,
it's been quite some time since I posted here, as I'm still very happy with my Sub 37.
However, I noticed a problem recently: While in Panel Mode, I press + hold the PRESET/EDIT button and edit some of the settings. For example, I like the pitch wheel to go up +2 and go down -12. I also activate the EXP. ATTACK options for both envelope generators. This alway worked, but since some time, those settings are often forgotten after switching the synth off and on again.
I looked through the manual and online resources, but couldn't find anything about how to store those settings as standard for PANEL MODE. I was always under the impression they would get stored automatically, but it seems they aren't.
Firmware 1.2.0, by the way (can't find updates anymore, where do I get them?)
Thanks in advance for help!
Best greetings,
Frank
___
Sub 37 Cookbook
My Website
Gear List
Me on Instagram
15" late 2013 MacBook Pro
Mac OS X El Capitan 10.11.3
fwilleke
Re: Sub 37 Panel Mode: Preset settings not persistent
Post by fwilleke » Wed Aug 07, 2019 2:53 am
Nobody has any idea how and when the Panel mode stores its settings?
Or is it just vacation time and nobody reads this?
___
Sub 37 Cookbook
My Website
Gear List
Me on Instagram
till
Post by till » Tue Sep 17, 2019 4:12 am
Guten Morgen Frank!
Version 1.2.0 is the newest available.
https://api.moogmusic.com/sites/default ... load_0.zip
The Sub37 is in the SYNTHESIZERS -> LEGACY PRODUCTS section of the moogmusic.com navigation at the left side.
But I can't help you on the main problem of yours, as I own no Sub37.
Razzia
Post by Razzia » Mon Oct 14, 2019 4:30 pm
I’ve had similar issues, but not necessarily with panel mode. I think it had to do with setting mod wheel modulation depth, and I’d set a value to 100 then a minute later the sound wouldn’t be behaving as expected, so I’d check in the lcd and mod depth would have changed by several points. I never did figure out what caused it. It was within a week of getting my sub and I just assumed there was some interaction that i was unaware of and unintentionally triggering
