1. When I record a step modulation (eg oscillator frequency)
then the recorded data is completely outside the scale of the knob.
And if I delete the sequence, the OSC is super deep or super high and I can not use it anymore.
Everything needs to be reset or I need to load a new preset.
That you do not hear what you record in the step mod has been discussed many times and I do not add it to the list here as a bug although I do it now hahah
Unfortunately, I find the sequencer currently totally useless for me.
That makes the company elektron much better.
From the sequencer I really expected more and I hope that this problem will be solved soon.
2. Insert 4 (Return) is only on the left side of the output
3. Initialize the sequencer Restarts the Moog One. (1.06)
5. The external input is getting louder per voice I play.
Regards
Brian
