Final audio output ?
Rarecomponentadsr
Post by Rarecomponentadsr » Thu Feb 21, 2019 1:53 pm
I see from most Modular users that in general, the final output from the Modular goes from a 902 VCA.
I would have thought that the final output would be from a CP3 or Matrix mixer, I know there can be no definitive output module but it does seem that most use a VCA as final output and now I'm wondering why.
Maybe this is something to do with frequencies or polarities ? Does anyone have any knowledge or info regarding final output ?
till
Re: Final audio output ?
Post by till » Thu Feb 21, 2019 5:55 pm
If you do one sound at a time on your modular, it is very likely that the last module needed will be a VCA. But if you got a bigger system, you might do a sequence with sound, a bass and a FX sound on one system. This is when you need a mixer on your modular for output or an external mixer. There are only a few mixers for modulars in Moog size that feature FX sends like most external mixers. I got a non Moog mixer in my modular with CV controlled FX sends and CV panning to get it all done on my modular.
But there is never a right or wrong in modular. It is always the result that matters, not the how-to.
CZ Rider
Post by CZ Rider » Sat Feb 23, 2019 1:37 pm
Rarecomponentadsr wrote: Does anyone have any knowledge or info regarding final output ?
Both the 902 and CP3 mixer are DC, so one could get a DC offset from the output. The 984 matrix mixer is AC coupled and better suited for output to a console mixer or recorder. DC offset can cause distortion and lower volume/headroom due to the offset.
Rarecomponentadsr
Post by Rarecomponentadsr » Sun Feb 24, 2019 10:16 pm
Thanks for this info...interesting about the 984
noddyspuncture
Post by noddyspuncture » Fri Mar 01, 2019 9:15 pm
I use a CP3 mixer as final out on my Modular because I mix 4 different sources, one being the built-in Minimoog. But then I also wanted to use my 1120 volume pedal.. so the CP3 feeds into a VCA, controlled by the pedal... :)
ummagumma
Post by ummagumma » Sun Mar 03, 2019 1:54 pm
till wrote:If you do one sound at a time on your modular, it is very likely that the last module needed will be a VCA. But if you got a bigger system, you might do a sequence with sound, a bass and a FX sound on one system. This is when you need a mixer on your modular for output or an external mixer. There are only a few mixers for modulars in Moog size that feature FX sends like most external mixers. I got a non Moog mixer in my modular with CV controlled FX sends and CV panning to get it all done on my modular.
till that is very interesting, which MU size mixer are you using?
thx!
till
Post by till » Tue Mar 05, 2019 4:53 pm
ummagumma wrote:till that is very interesting, which MU size mixer are you using?
I use a Moon Modular 543 with two 543E FX sends
They are pictured here:
http://www.lunar-experience.com/vcas.html#543
ummagumma
Post by ummagumma » Wed Mar 06, 2019 7:18 pm
hot damn, that looks pretty slick!
