Volume knob weirdness?
Just got my One. Loving it so far.
The volume knob (output) is strange. At 12 o'clock, the One is dead silent, no sound, even on INIT patch.
At 10, the One is completely overdriven and distorted. Anyone else?
Could be a pot calibration thing I suppose.
Re: Volume knob weirdness?
Is the Headphone volume behaving the same way?
Yup, exactly the same.
I played a Moog One in store and that's what the headphone jack was doing. It was really weird but perhaps the volume is exponential instead of linear? Hence why it cuts in and out so quickly and aggressively at full volume. I still don't have my unit yet, but I look forward to hearing what others' experience with this has been.
- _DemonDan_
Hi Toom,
Have you installed the latest Firmware 1.0.2?
If not do so. Not that there's something specific in there about the volume knob,
it's just an easy way to clean out any old cobwebs.
FIRST - Save your custom presets to a thumb drive on the LIBRARY page.
Follow the included directions for installing v1.0.2.
It's also IMPORTANT to create a new USER SPACE by pressing SETTINGS, then the
LIBRARY soft button, then EDIT USER SPACE, then highlight the + + + +
and press the big knob. Choose CREATE FACTORY.
This will ensure that you have the latest presets that best jibe with any
changes or new features. If you have your own presets, just load them into the new User Space.
_
_DemonDan_
_
I experienced a weird volume issue yesterday, but it was on the VCA Level knob. There was a half second latency between moving the knob and getting the volume of that synth to respond. It happened across all 3 synths.
A reboot made the issue disappear, but I wanted to mention it here for the record.
Hello - took delivery of my 8 voice yesterday.
I’m too getting this issue, it came with 1.0.3, however, I still reinstalled from scratch to try and resolve.
Between 7-12 o’clock positions there is hardly any signal, from 12-to 3 o’clock I get signal but beyond that it’s just distortion, clipping and noise which I feel is really odd behaviour.
I’ve also noticed the envelope pots on an innit patch don’t react as I would expect, my only reference point is the Sub37, I appreciate there is a difference but again with all the other hardware synths I have the curve of the pots seems to behave normally compared to this machine.
Similar to mine. I spoke with my supplier and Moog, I also shared them some audio examples. The Moog engineers said that the master volume is configured to be at its max volume at the 1 o’clock position with additional additive gain from then on which needs to be seen in the overall gain staging of your output.Between 7-12 o’clock positions there is hardly any signal, from 12-to 3 o’clock I get signal but beyond that it’s just distortion, clipping and noise which I feel is really odd behaviour
Seems a strange config but I now leave the Master volume at 1 o’clock and run it straight into my interface and use the VCA volume to tame signal.
Ian
Just received my 8 voice. It's great, but yes, I'm experiencing the same volume knob issue. My unit shipped with firmware v1.1.0 installed, so one would think that if this were a bug, it would have been addressed by now. If the instrument truly is configured so that the master volume is at it's max at the 1 o'clock position, it seems to be a pretty odd design choice. I've owned a million synths, and none have operated like that. The distortion that is introduced beyond the 1 o'clock position is not the most musical, which leads me to believe this is a bug. Checked with a buddy who owns a 16v, and his exhibits the same behavior. Does anyone know if this might be addressed in future firmware updates or if it really is an intentional design?Iaamusic wrote: Fri Mar 15, 2019 3:55 amSimilar to mine. I spoke with my supplier and Moog, I also shared them some audio examples. The Moog engineers said that the master volume is configured to be at its max volume at the 1 o’clock position with additional additive gain from then on which needs to be seen in the overall gain staging of your output.Between 7-12 o’clock positions there is hardly any signal, from 12-to 3 o’clock I get signal but beyond that it’s just distortion, clipping and noise which I feel is really odd behaviour
Ian
Thanks folks! Other than that, I'm loving the Moog One.
Moog: Model D, Voyager, Sub 37, ONE 8V, Minifooger Delay (x2)/DSI: Prophet 6, Pro 2, Prophet REV2 16V/Nord Stage 2 SW73/Studiologic Sledge 2.0 Black/Waldorf Iridium desktop/Arturia Matrixbrute/Behringer Mono/Poly, 2600/Mellotron Micro/Modal Cobalt 8x
